I'll try em thanks for infoPossibly. However, it will need to come apart to do it correctly, so maybe try Evil Bay for a used Swivel Bracket. Be aware that there was still a 2 Stroke 50 being made that Yr too, and it used an entirely different Transom and Swivel Bracket
I bought boat at end of last summer and I did catch a rock one of my first times out, but I was going really slow so I don't think that done it. I haven't had and impacts this year it may have been like that when I bought it I don't knowI would say very bad and if that were my boat I wouldnt use it untill it was fixed because it looks like the sort of crack thats going to get bigger untill it snaps right thru ....could cause loss of control if it lets go at speed ....and Im thinking replacement part (new or good used ) but Id also be wondering what caused that .Did yo have some sort of impact or other "mishap"?.
Yeah but its not just a case of putting a bead of weld on that crack ,there is a LOT of prep work needed before welding . You would have dismantle the thing and then vee out both sides from top and underneath and be sure you had veed out all of the crack down to clean metal (or it will crack again ) a lot of the corrosion resistant paint coating removed (so it doesnt melt and contaminate the weld coz then you gotta start again )and then welded in stages so as to not distort the thing . I would be surprised if getting a new one wouldnt be a better option .Is this something that could be welded
Ah ,you maybe right . Its good that your vigilant and spotted that before it turned up on your doorstep.Found this one on e bay must be a weakness in this part it's cracked in exactly the same two places
