Thinking about selling my 90hp 1986 Mercury inline 6
airshot
Dealer friend said---" I love the new 4 strokes "---Folks make regular appointments for service.-----Don't need a super mechanic to change oil / filters / plugs.-----All good $$$ that 2 strokes never brought to the shop.
Neighbor took his 4 yr old four stroke outboard at the end of last season for a tuneup so he would be ready to go this season. Oil change, filter, plugs, lower unit change etc.....typical motor service....cost him almost a thousand dollars ! New motors are expensive to start and keep on being expensive after you own them.....could have done a number of 2 strokes for that price!
Gotta save a lot of fuel to recoup that.....
ab59
Ensign
I have had enough of carburetors constantly needing service. I just finished rebuilding 3 for the inline, and I have the 20 hp Johnson that I replaced with the 20 hp 4 st. that I'm about to rebuild as well before I sell it. Every time I went to trailer the boat that 2 str would die and leave me scrambling to get the boat on the trailer while everyone was watching the show. Not to mention the rainbow colored water that the motor makes when running. I will take the 4 str anytime. What little time I have left on this earth will not be fighting with a 2 str, but enjoying a motor that I can put in almost every lake, trouble free. Well, for the most part. I'm 70 now so I look for peace and enjoyment.
Mc Tool
I get that your past faffing about with carbs but they shouldn't be "constantly needing service" as long as they are not worn out, and are being fed good clean fuel . A lot of ignition issues are blamed on carbs ( and vice versa ).🙂
airshot
Haven't had a carb issue in 20 years and I gave lots of toys. A simple fuel stabilizer removes most all carb issues or your buying bad fuel. People don't realize how much of our fuel we buy is contaminated to begin with.
Proper maintenance solves most issues, carb kits are cheap when compared to a fuel injection repair.
flyingscott
Any 4 strk with a carb will be a maintenance nightmare.
Mc Tool
Depends 😁 anyone used to doing their own maintenance on a multi cylinder motorbike would probly think they were easy .
I have had my 3 cylinder carbed Honda for 8 years now ...not so regular use , and all I have ever done was ballance them and fitted new bowl drain tubes .......so far ....probly 🤬 jinxed it now 😆
airshot
Carb issues are carb issues, whether two or four stroke makes no difference, other than four strokes are much more difficult ( expensive) to work on. Carb issues can be easily stopped by using good fuel and add an additive. My 1992 has never had the carbs touched other than new fuel hoses and runs excellent !
flyingscott
Nope your wrong
flyingscott
Nope your wrong
flyingscott
Carbed 4 strks are 10x worse than 2 strks. To meet emissions the the idles are leaned out so far they are prone to plugging up the jets. That is common knowledge and a lot of times carb replacement is mandated. So no they are not the same as 2 strks.
Mc Tool
Nope your wrong .....x10
Gee, I always found that boys will be boys and carbs will be carbs.
Seriously, keep your fuel fresh, drain or run 'em dry when layup time and they should not need any work for a decade or more.
Leave fuel in them or use old fuel and you will have issues. Just my experience.
Mc Tool
Guess I should have added, 4stroke with fuel injection.
Ah ,I dunno 🙂 Honestly I think one of the biggest frustration issues with carbs is peeps believing they have been completely cleaned when they have not and /or not fully understanding how they work.......and peeps that cant resist having a fiddle .🙂🙂
jimmbo
Far easier to understand how a Carb works, how to troubleshoot it, and how to adjust and/or fix it. EFI is up there with Voodoo, and other Poltergeists
