- Joined
- Jul 23, 2011
- 53,043
Impeller on a cobra is a 5 minute job
next time when you have to do the compression test just hook up the water hose and leave it on not full blast but like half open. I don't know about the EFI engines but on the carbed engines with the old style distributor, I always grounded the coil lead, you don't want spark sent to the spark plug wires now disconnected with the cyls pumping out fuel vapor!Fried my impeller with all the compression testing I guess. She's a mess.
Hello,Yes if it has a crank sensor for EFI, a failing crank sensor could do something similar, on my old '98 Jeep 4.0 when the crank sensor was starting to fail, one sign was the tach and idle would drop and recover, eventually that turned into a higher speed miss, followed by a reluctance to start, ending in a refusal to start. It did not set a code till the sensor totally failed.
I have a 1988 OMC factory shop manual but this model is so much newer that there's nothing that's similar. In the vid it looks like a Ford 5.0 with the EFI system, so I can't help there. If it was the older models with carbs and points, oh yeah I know THOSE things quite well lol!
Post up pix of the engine and drive.
A bang if you have a dog clutch Cobra might be wear on the clutch dogs or fwd gear causing it to slip out of gear under power, but it could be a lot of other things....
Here's a guess on what you might have....
EFI Ford engine, and the last of the Cobra Dog Clutch drives....
the Cobra dog clutch part I am familiar with and they require a good shift cable in good adjustment to last. I have had the same cable on mine all these years (owned 24 years) and it needed adjusting when I first got it in 2002 and then again about 10 years later, I learned how to do the tricky adjustment myself, not really hard. It has required very few repairs, over the years in salt water use and moorage. A few seals, bellows 2x, gimble bearing once, and I rebuilt the trim rams a few years ago.
You need a good OMC mechanic who knows about the EFI engines, I don't, and if I had one that was acting up, due to most of the parts being NLA, I'd simply convert it to a 4bbl carb and Davis Unified Ignition distributor, that eliminates all the headaches of NLA OMC EFI and electronic ignition parts.
good to know and I kind of suspected that.Hello,
I was reading thru all these threads and i want to offer some insights. I have a 1994 Larson that has the same 5.8 EFI OMC ford engine. Most all the EFI parts are no longer available, such as sensors and different electrical parts, however, apart from the distributor and the alternator which are marine specific parts. The rest of the system is essentially a Ford EFI system that was commonly used in many other vehicles, such as trucks and even the 5.0 fox Body Mustangs. All the sensors and other related electrical EFI parts can readily be sourced through any online auto parts retailers. Just look up 1993 or 1994 Ford bronco with 5.8 L EFI.
I know how difficult it is to keep these older engines running with these NLA parts that are difficult to impossible to source from regular marine parts retailers. Good luck.
That's not gonna work, if you remove the impeller housing it looks like this:
(ignore the bolts, that's for pulling the water pump plate to replace the seal)
so the 2 large holes at the bottom, are the ones where water comes up from the lower unit and then gets pulled into the impeller and sent thru the transom mount.
If you want to make sure there's no clogs:
remove the plastic impeller housing
get a helper
Test #1 :go up to the front of the engine, disconnect your raw water intake hose at the 'stat housing. Put the water hose in the raw water hose and turn on the water. Have your helper watch, they should see water spurt out of one of those large lower holes in the impeller mount plate
Next
Test #2 re-connect your raw water hose at the stat housing, with the plastic impeller housing off,
hook up the water muffs and turn on full
water should now come out of the other large hole in the impeller plate
that tests for blockages in the water intake in the drive and leaks from the water tube grommets.
if test #1 is not good you have a clog in the p/s cooler you might have to remove it and clean it out
if test #2 is not good you may have to split the drive (not a fun job take it from me, been there done it 2x) and clean out the water intake area in the lower unit. I had such a problem with barnacles and other crap growing on that plastic screen that I remove it about 13 seasons ago and it's been much better. Lastly replace the water tube grommets. If you don't have an overheat, they last a really long time.
You're in freshwater right?
then some of these jobs should be a LOT easier than they are for people like me in the salt pond.
Look at how narly this drive looks, that's 24 years of mooring and running in salt water, but, a good Cobra will REALLY last. Very few problems overall.View attachment 417275
Yea new impeller, lots of water flow out of the exhaust. Maybe dirty injectors. Maybe I'll run a fuel injector cleaner through it. It doesn't like full throttle at all. Backfires and sometimes will idle down and die.Did you replace the impeller? Your temp
@ idle should be 160-170 with a 160 stat.
You put in new spark plugs right?
30-40 psi is ok for oil pressure at idle. Mine idles @ 40 cold idle to 30/25 hot idle. At high rpm it hits 55-60 on the gauge.
The missing could be dirty fuel injectors but I’m not familiar with these EFI systems.
Stupid question but how do I check the thermostat?Backfires could be lean fuel mix (clogged injectors) or an intake valve sticking open. Did you check your thermostat? It should start to open @ 160* and be fully open @ 180*
You get a pot of water, a coat hanger and an old fashioned radiator thermometer; they read up to 240* or so. Fill the pit with water and take the coat hanger wire and hang the stat by it in the water so it doesn’t touch the pot. Then heat the water till the radiator thermometer reads about 160, the stat shouod start to open. It should be fully open at about 180.Stupid question but how do I check the thermostat?
I do, yes, he gave me all of them except the one for the drivePS do you have a manual? It would help a lot that’s how I learned most of what I know. You can still get factory shop manuals the OMC ones are quite good.
Oil looks good. Took it out for another run, it started sputtering and we got stranded in the middle of the lake. Not fun had to get towed back. I'm wondering if there's water in my tank or somethingGreat so how does your oil look?
