1988 125 HP Force Rebuild
Sandy-man
Its happier😁.
Is it possible you have dialed in a tad more spark advance during reassembly ?
I'm not sure how to change the timing. I didn't adjust any linkage of anything. Is this where timing is adjusted, in pic? This is the first outboard motor I've ever worked on, so I'm kinda clueless with some things. I've rebuilt Chevy 350 motors, motorcycle motors, small engines for lawn mowers and such, but these outboard motors are a completely different animal.
Folks often learn about outboards / and water pump operation the hard way.----Through an empty wallet.
Sandy-man
Lol, I'm climbing that hill now. I've spent a pretty good chunk of change on this motor already and I know for a fact I'm not done. New used cylinder block as well as inspection and rigid honing, new pistons, wrist pins, rings, complete gasket kit, and the list goes on. Cha ching
Mc Tool
They sure are , I dont know your motor but basically two stroke outboards at idle spark timing is at or even after tdc ,1st (roughly 1st ¼ ) part of throttle lever movement only advances spark ,then from ¼ to ¾ throttle lever movement there is a bit more spark advance and the throttle butterfly in carb goes wide open ,and then from ¾ throttle lever movement to full speed the ignition goes to full advance. There is no auto advance ....and if you slam the lever right down quickly the spark will go full advance while motor is still at idle speed .........so yeah , a whole different animal .
Throttle lever linkage is connected to the ignition timing plate under flywheel and rotates this plate to advance or retard timing and ( on my motor ) there is a cam on the timing plate that acts on the carb butterfly to open them . The carb butterfly is not directly connected to the throttle lever . Idle speed is generally set by adjusting the spark timing . Setting this carb -idle-timing thing is known as "link and sync " and you need to get this adjustment right for things to work as they should . I would get a workshop manual ( probly a pdf on line ) .
I gotta say that when I 1st saw such a set up ....after dealing with cars, bikes and chainsaws I couldnt believe what I was looking at ....seems real half arsed but it works well .
A manual is the best money you could spend on your motor 🙂🙂
Sandy-man
Alrighty, thanks again, Mc. I really appreciate it. I just watched a video on YouTube about it too. I never realized just how much info you can find on YouTube, amazing source.
Nordin
Sandy-man there is a post in the top of this forum made by Frank Acampora (who is not with us anymore) to do the link and synk on Chrysler/Force 3, 4 and 5 cylinders.
Read that post and check your engine, remember that on these engines you do not set the timing at idle.
You set the timing at WOT and then the timing at idle will be what it will be.
You adjust the idle with the screw at the timing tower which rest against the block.
Sandy-man
Ok, thanks for the tip, Nordin. I will check that out before I try to adjust anything.
lostinohio
When everything is said and done I got one more project for you to do. I have the same motor but an 87. Do the tell tail install that's in the stickys. You can thank me later.
