findinghomer
- Joined
- Nov 7, 2009
- 378
Hi guys Okay I've done a lot of research on the internet and iboat, and I'm stumped still. Hoping someone could steer me in the right direction with my individual problem. Took the boat out of storage from winter, everything fired up just fine, Strong crank and fired with minimal effort. went on the lake everything was fine except for a few hard starts went hot. I got it home to try to diagnose that problem and ran it on muffs , it fired right up nice and strong. I let it get to temperature so I can try a warm start by shutting it off and then restarting it 10 or 15 minutes later. I did that, and now I have a really slow crank as if I have a low battery. I know the batteries are 100% charged I even pulled the working battery out of my truck for testing, same issue. Figured I had a starter issue, because I replace it with an aftermarket one 7 years ago. So I just went ahead and got another one. Even with the brand new starter, it's still cranking slow. So I pulled all the plugs, no water came out, cranked it with the plugs out still cranks slow. My next step was to check all of my connections, I did notice one of my battery terminals was loose out of the eyelet. Figured that was my problem, so I redid it. Now it's nice and tight and even greased up. Still a slow crank. So I figured I should just redo all of my battery connections including to the starter, or maybe it's my ground? So I traced my ground wire on my battery, apparently the ground wire attaches to battery one, and just loops behind the engine attaches to the ground of the other battery, it's not grounded to the engine? Is that normal? I know that cable did short out about 10 years ago and melted the insulation to it, but being that it was just a ground cable I never fixed it. I'm thinking this could have something to do with it as well, but shouldn't it be attached to the engine? This is where I'm really confused now , the negative posts on each battery just attach to each other. I found the ground strap, there are two grounds coming off of them they are smaller wires, can't see where they go maybe a ground bus? the ground seems nice and tight but I just don't understand why the batteries aren't grounded lol. Anyway I'm pretty stuck and I got a boating trip in a couple weeks and I'd like to try to get it fixed so I figured I would reach out hoping someone can help me. Thanks!
