How long after you were done the seafoam treatment, did you replace the plugs? If you replaced them, right after using the Stuff, and before you ran the Engine, that may have fouled themI put in new spark plugs since seafoaming.
I only replaced them a few days ago. I wanted to make sure all 'carbon' went on the old plugs. But yes, I'll check them again and upload a picture here tomorrow.How long after you were done the seafoam treatment, did you replace the plugs? If you replaced them, right after using the Stuff, and before you ran the Engine, that may have fouled them
Have you looked at them?
.How long after yo
Keep in mind, these engines do not sit and purr like an Auto Engine at idle, well maybe a Car motor with a Higher Performance Cam. They burp, fart, and jump around, even when they are running perfectly.
Here is a big single banger two stroke at idle ...admittedly not really comparing apples with apples but as jimmbo says they do not idle smoothly . Imagine 2,3,4,or 6 of these cylinders together .Keep in mind, these engines do not sit and purr like an Auto Engine at idle, well maybe a Car motor with a Higher Performance Cam. They burp, fart, and jump around, even when they are running perfectly.
Thanks, Yes, I had a Yamaha 80 when I was 8. Then a Suzuki RM80 until 1979, then a Husqvarna 250.Here is a big single banger two stroke at idle ...admittedly not really comparing apples with apples but as jimmbo says they do not idle smoothly . Imagine 2,3,4,or 6 of these cylinders together .
I had a 2000 ish yam 90hp 2 stroke outboard ( 3 cylinder) that did this ....its music to meI love 2 strokes .
https://share.google/Iz2tPE8JIiNN22RJr
I had go carts first, mini bikes...then a yz 80 then eventually had a YZ 400 before retiring to outboards and fishing. Doing a "Raggedy Ann in the whoop-de-doos solved that!Thanks, Yes, I had a Yamaha 80 when I was 8. Then a Suzuki RM80 until 1979, then a Husqvarna 250.
YZ400e ,then a few IT's . I have done the raggedy ann in the whoop-de-doos ....just got the timing wrong and slammed into the uphill ....still hurts just thinkin about itI had go carts first, mini bikes...then a yz 80 then eventually had a YZ 400 before retiring to outboards and fishing. Doing a "Raggedy Ann in the whoop-de-doos solved that!
Hey! were COX Cars and Planes 2-Stroke? I loved the smell of their exhaust.I had go carts first, mini bikes...then a yz 80 then eventually had a YZ 400 before retiring to outboards and fishing. Doing a "Raggedy Ann in the whoop-de-doos solved that!
Yep ,I had Cox motors as a kid ,a babe bee .049³" and a .020³" motors . Yes the caster oil in the alcohol fuel had a lovely smell ...stayed on your clothes and hair for days ....according to my MumHey! were COX Cars and Planes 2-Stroke? I loved the smell of their exhaust.![]()
I had it in a 55 gallon drum cut in half one of the runs.How does it idle with some back pressure ???
Here are the old plugs that I ran some after the seafoam.How long after you were done the seafoam treatment, did you replace the plugs? If you replaced them, right after using the Stuff, and before you ran the Engine, that may have fouled them
Post 99I ordered a shop manual from eBay today. I still think it's air/fuel related, but I'm just going to go through everything from spark to stator. I figure if I'm at 120 compression, good lower unit, and as clean as this motor is.... Might as well.
