Sputtering Johnson V4 90hp - 1994
Berdink
Thanks racerone.
I always post back.
It's frustrating reading threads where someone asks for help and then disappears. Rude.
Berdink
I was planning on just blowing out every nook, cranny, orifice, jet, with spray carb cleaner.
Should I dip it in my Berryman's?
Doesn't Berryman's harm the outside finish on the carburetors?
The only reason I ask is I saw a guy on YouTube (Brandon's Garage) do it. But his were pretty dirty.
jimmbo
Okay
Okay, you're of an older generation. Milk Bottle?
I remember the Milk Man and those cold glass bottles in that metal carrier and left on the porch. 😊
Looking at it again, maybe it looks like a Decanter for Wine...
Berdink
Well, I feel better seeing the carbs need help.
Does these green colors mean water sat in the bowls for awhile?
The motor was laying on its side when I first got there, and then we hoisted it up and put it on stand to run it.
jimmbo
Those Tubes are Brass, and Brass is an Alloy containing Copper, which when oxidized by water, creates the Green Oxide. High Humidity will also cause that.
Berdink
It's interesting one side is dark goopy and the other side is dry green corroded. I'm guessing it was sitting on that one side for some time.
