A few things I should point out for future reference.
@damo79 has a DTM engine not the DTS engines that
@tpenfield has.
A DTM engine has a mechanical throttle control at the helm and a mechanical throttle and shift cables going back to the shift plate on the engine. Also this is a non cat engine.
This changes more then a few things on how we troubleshoot and importantly how we read Diacom files.
But looking at the REC files we have at this point might be a waste of time -- they might be corrupted.
It is to be expected that the PCM won't open the throttle plate 100% when RPMs won't get above 4500 with a full load. The PCM won't feed more air then the engine can use. Most everything on this engine, spark, amount of air supplied to engine and amount of fuel supplied to engine are controlled by the PCM. And the PCM is using many things to make decisions.
What we are looking for, is basically why this engine won't reach WOT.
Let's assume this boat should reach 5200 RPMs @ WOT (or close) like the test boat did with a 19p aluminum.
5200-4300=900 RPMs
1/6ᵗʰ of 5200 is 867 RPMs
Maybe we have a cylinder not doing anything?
