How do I Remove Very stuck on Exhaust Manifold Gaskets?
KM7
I'm changing the exhaust manifolds. They came off easily, but the gaskets are really stuck on the engine block. They may be the original and 35 years old ! I've tried a hard plastic scraper and gasket removal spray. I have a one-sided razor, but I'm concerned about cutting into the metal. So far, I'm not making much progress. These original gaskets seem Very tough!!
Any suggestions? Heat? A drill with a (soft) wire wheel? Keep soaking with gasket remover? What else?
Thanks
Soak with penetrating oil
Then use a metal paint scraper or a gasket scraper.
I have use wood chisels in the past
Mc Tool
Paint scraper ....not to wide , maybe 1 inch and cut half the blade off to stiffen it up a bit and grind a bevel on one side ....like a wood chisel . Ideally you dont want to shave any metal off but as long as its not a chunk the odd nick isnt going to ruin the gasket surface . Exhaust gaskets are fairly thick and when fitted with a bit of exhaust sealant not a problem . Cast iron is pretty hard compared to aluminium . 🙂
IslandExplorer
Oscillating multi-tool with nice sharp straight flat scraper blade for the win. Usually that gets right under it and will do a good clean job, and it's easy on your hands.
Can ping it with light ball peen hammer taps directly on it to get cooperative fractures started if extra resilient gasket. Go easy with hammer. One ping only.
KM7
Just to be clear, I'm trying to get very old gasket material of the cylinder head not the exhaust manifolds. I plan on replacing the manifolds.
Thanks for all the suggestions above. I will try a combination of all of them,
I have PB Blaster Penetrating rust remover and I also have CRC Gasket remover. I have been spraying with the CRC and letting it soak but the gaskets are Very hard after 35 years!! I'm not sure that the CRC is doing much. I can keep spraying and letting it soak. I also have a drill and wire wheels. That seemed to work at least partially, but it takes a long time. I'm taking it slowly to be sure not to wear down the mounting surface.
Is there a chance that the gasket material contains asbestos? I'll use a mask !!
Lou C
Maybe heat it with a heat gun carefully…I had a heck of a time getting the old gasket material off. Took quite a while!
Cast iron cylinder head? If so, they are pretty tough, unlike aluminum.
There are stamped steel "holders" for single edge razor blades, used for scraping paint. A couple of new blades ought to get it. Be careful on aluminum components, but I do not think you will damage the cast iron components.
If that fails, which would be unusual, you could use a flat piece of steel as a sanding block, with find sandpaper.
KM7
I was able to get all the gasket material off the engine block. Here was the method:
1) Vacuum all around the exhaust and the spark plug holes
2) Use the vacuum as a blower and blow out any debris
3) Block the exhaust ports with sponges cut to size
4) Block the spark plug holes with tubing and rags
5) Soak the gasket with PB Blaster Rust Remover (I'm not sure if it worked better than Gasket Remover spray)
6) Use a combination of: plastic scrappers, metal putty knives, Razors with a short holder, and a razor with a 5 inch holder.
7) Use a hammer and a screwdriver, lightly tapping on the gasket to split it ( This was very hard, baked-on gasket material after 35 years.) See pictures.
8) Carefully remove the stuck-on gasket material. Apply more PB Blaster as needed. The cast iron is very hard and it was easy to avoid scarring the cylinder head.
9) I plan on going back with a brass wire wheel and/or a green scrubbing pad for a final cleanup.
Note: The gasket material was very dark and sometime hard to tell if it remained. One way to tell was to try to scrape it. If it turned white, that is gasket material. Once the gasket is removed, the cylinder head is darker and more scraping will NOT turn it white.
See pictures attached.
Lou C
That’s good the cyl head gasket isn’t as fussy for sealing as the manifold to elbow gasket
IslandExplorer
Wow, that looks like that was tough. Crazy how resilient old baked on gaskets can be. Good job not giving up.
And I'd definitely suspect that there could be asbestos fiber in it. The old stock gaskets, brake pads, etc were all tougher bc of it. When in doubt def wear a dust mask if you can. Lots of marine products are extra HD (aka the real deal) which also usually means extra toxic fumes and dust.
