Prop nut for Merc 25 hp?
nola mike
While installing my prop realized too late that the nut was nylon. Looks like the part # is 11-88228. Any reason not to go with a regular brass nylock nut, and does anybody have a part # or size?
Fun Times
Take note of the notes which includes a size of reference (M12)
664011912--NUT-Brass (M12)-For SS Propellers
$0.001
6688228NUT-Nylon (M12)-For Alum Propellers$2.921
nola mike
$0.001
I wonder why the spec different nuts for different props? Anyway, I don't see a reason not to use the brass nut, if I can find an M12 x ? Nylock.
jimmbo
Might have something to do with the SS prop having greater mass, and thus more inertia,
Stainless + aluminum + copper alloy (brass) is a recipe for galvanic corrosion.
nola mike
I was thinking that as a reason not to use SS nut with aluminum prop, but brass nuts are commonly used on both, no?
Yes, for why nylon isn't used on stainless... But why not brass on both? Corrosion like Scott said or just to save a buck?
jimmbo
Lots of SS Props and AL Props use the same Prop Nuts, so who knows....
