Are Yamaha fuel filters universal?
boscoe99
If the Yamaha part number is not the same then the filter is not the same.
The 65L-24563-00-00 filter is used in a number of different Yamaha models.
99yam40
if he is buying it at the Walmart link he posted, I am sure it is a Chinese knock off, not a Yamaha OEM filter
Mc Tool
Do you think Yamaha make fuel filters ? .....about as much as they make spark plugs ....I wonder just where it is they get them from 🤔🙄
Jeff J
Must know the correct part number for the model and serial number before ordering anything. The parts diagrams are available for free all over the internet.
That link lists the F150. I have worked on the 2011 and newer F150’s for the last 5 years and have yet to see that filter.
boscoe99
Not all Yamaha F150's are the same.
Jeff J
In a duplicate thread I qualified my response with none I have worked are salt water motors. The 2011 here is a TXR so once again I will repeat, part numbers must be checked against the serial number. It not enough to google “yamaha Fxxx fuel filter”.
boscoe99
Problem with checking by engine serial number is that many engine serials are not in the Yamaha USA database. Certainly motors not distributed by Yamaha USA are in there. Many older motors distributed by Yamaha USA are not even in the Yamaha USA data base.
