Successful Deletion of VST, Primer, & Fuel Pump
Longarch
To avoid the high cost and desperate searching for used parts, I've successfully replaced the Vapor Separator Tank (VST), Choke / Primer, and Fuel Pump on my 1998 Johnson 115 Fast Strike outboard. It has been tested and performs without flaw. The design was approached to have less-costly replaceable durable components designed to work with petrol and oil mixture.
GOALS
1) Create a vapor / fuel return-to-tank system with adjustable fuel rail pressure
2) Maintain a low-pressure, high-volume fuel supply
3) Ensure proper filtration without loss of fuel flow and/or pressure
4) Have a working choke / primer fuel-to-intake injection system
5) Have a back-up fuel pump
TRADE-OFFS
1) Required to pre-mix oil and gas (-)
2) No fear of fuel pump failure (+)
3) No primer bulb to hand pump (+)
4) Ensured fuel line air bubble removal (+)
5) Electric fuel pump pressure not deadheading (+)
6) Fuel between outboard and tank is circulated and therefore does not heat up (+)
7) Less-costly replacement parts that are durable and easy to get (+)
8) Sit down, turn the key to ACC position, wait 5 seconds for the fuel pump to pick up fuel, depress switch for a second to inject fuel, and crank outboard (+)
  • 7 Boat - Video.mp4
Crosbyman
Does the FICHT system provive for oiling of innards I am thinking ETEC with separate oiling no need for fuel oil mix in ETECs
Crosbyman
how does the oil fuel mix bathed the crankcase if direct injected for combustion
First of all, you do not have a fuel rail. Those supply fuel to injectors, not carbs.
Secondarily, there is no reason to return fuel to the tank, unless your fuel pressure will override the carb inlet needle.
Thirdly, the components you replaced last decades w/o replacement. I have a 1998 Johnny 150HPV6. I have never had to touch the primer, OMS fuel pump or VST.
Fourth, how do you power the electric fuel pump safely, such that if the motor stalls and a fuel line leaks, the elec pump will not fill the cowling with fuel?
Inquiring minds....
Longarch
1) Corectiin - Fuel manifold (X2) supplying two carbs rack.
2) Return keep fuel cool and reduces chance of 'vapor lock' Fuel return also returns any 'bubbles' in fuel back to tank.
3) The outboard is decades old and the fuel pump has already failed along with having VST issues.
More???
Gee, the VST solves the vapor lock issue and bubbles issue. In addition, the VST is simply a tank with a fuel inlet needle, just like a carb. I have never had an issue with the one on my '98. I never priced a new inlet needle and gasket for the VST, but I expect it to be cheap and available.
That being said, how is the electric fuel pump powered safely?
Longarch
Sorry, Chris1956. I was using a cell phone and failed to see question / concern #4. I plan on using a tach safety sensor to shut the fuel pump off of the engine fails. Yes, that does not eliminate the issue if a fuel leak developes.
saltchuckmatt
It's got a "roll over" switch. If your upside down, your safe!
Definitely an issue. Boat fires are a major bummer.
Longarch
Yes sir. I had VST warpage issues. A new gasket is very cheap but did not fix my issue.
I never heard of VST warpage. The carb bowls do warp and need to be replaced.
If you power the electric fuel pump from the starter solenoid for cranking and via a relay from the voltage regulator for running, with appropriate diodes, it can be made safe.
I really think you have solved a problem that didn't exist. Best of luck with it.
Berdink
I think I posted in your dupe thread.
Does the electric fuel pump shut off when the engine dies?
Crosbyman
Powering the FP from the regulator output with a few blocking diodes to prevent feedback B+ from the solenoid should do it & kill the FP if rotations of the FW stops.
The initial "FP power up" to fill carbs could be activated with a "fuel up" shot of B+ from a "normally open" push button
After start up the B+ from the regulator/rectifier would maintain FP operation
no need for a tach sensor
better yet don't mess with design intent ....millions of OB work fine with OEM parts :)
jmho
Harkonnen
Love the idea. I’ve had both fuel pump and solenoid failures on a 2005 J115PLSOR. The solenoid was replaced with OEM (luckily, still available, but pricey), while the pump was replaced with a premix retrofit kit. That, in turn, got a 3D-printed mounting bracket because the supplied bracket bolted to the rather flimsy vapor tank support, which is no longer available, AFAIK.
And before anyone starts on 3D printing: it’s been almost a year with no visible issues. Just use ASA rather than PLA, set infill kind of high, and make sure that top/bottom/perimeters are adequate. And watch for warping.
Now, someone needs to come up with carb replacement TBI system for this family. That would be a "shut up and take my money!" kind of product. :LOL:
(This is an older iteration of the bracket, replaced after a few days with a redesigned version that is still in use.)
W
When you say solenoid, do you mean primer solenoid? A premix pump like you installed, is a standard solution. The Maxrules site has those kits as well as OMS pump rebuild kits.
I do like the oil injection on my '98, so I opted to replace the OMS pump last year. I probably could have gotten a few more years out of the original OMS pump, but It was leaking at an oring sealing the mixed fuel outlet.
Harkonnen
W
The thingie with the red lever, top right. Aftermarket ones tend to have the wrong inlets.
Yep, I used a kit for the pump replacement - not sure which manufacturer. I wasn’t happy with the bracket bolting to the vapor tank support, so I made a different one that bolts directly to the block. Reused their fuel connector.
