2001 Volvo Penta 5.0 GL cracked block
Laneman25
Wish I wasn't posting this but it happened. I would say that I carefully drain it each winter but obviously I didn't do something right. I have fond memories with the family on this boat. I always drain the two plastic plugs under the risers, both block drains, and the water pump. I also run a zip tie in and out of the drains to make sure all water comes out. The crack is T shaped just below the dipstick tube where yo see the water stains. Any chance of a JB weld or something, or is it toast?
Gee, sorry that happened. Water is tricky and can get trapped in areas of the block. I always filled my block with straight automotive antifreeze for winter, since I was always uneasy about water hiding somewhere.
The good news is that rebuilt blocks are plentiful and relatively cheap. On MerCruisers, blocks are pretty easy to replace, once you get the hoist figured out. Hopefully V-P is the same.
Laneman25
Well I've watched a few videos and several boat owners had long term success with JB weld. If anyone here has tried it please add some tips.
Lou C
You also have to pull off the bottom of the big hose between the 'stat housing and the front circulating pump, did you do that?
GM cast iron blocks were never meant to be open cooled due to how cast iron rusts. So many rust flakes it is easy for passages to get clogged with rust flakes or even just sediment etc. from shallow water. I have a set of picks that I use to rod out the block drains each time I winterize it. When/if I repower my boat it is getting a half closed system for the block. Much better, easier to winterize and longer engine life.
One thing I noticed is this, it really helps to fill the block with the correct PG antifreeze for winter, because I have found that I rarely if ever have to poke one of the drains to get it to drain fully. It reduces corrosion when the boat is in storage, that's my opinion. And unlike many here, my use is 100% salt water. Block is original, heads were replaced 9 years ago (past overheat damage).
Laneman25
Yes, pulled the big hoses from water pump
Lou C
So then I’d guess there was some sediment in the bottom of the block passages that prevented all the water from draining.
Kosmofreeze
I hope you can get some more life from your engine with JB Weld. However, when it comes time to sell, I don't really think that there is any difference between a cracked block and a JB welded block ... good luck.
I always cross my fingers every spring ... did I get ALL of the water out of the block? I always take a 5 gallon bucket of PINK antifreeze connected to the muffs on the final run until I see PINK out the exhaust. Then I drain the risers, block plugs and hoses. With the block plugs out and the impeller output hose disconnected at the top, I fill the hose with PINK until the PINK is running out of the block plugs. In my mind, I just filled the the block from the bottom up with PINK. Probably a belt and suspenders approach but I've made it through many northern Minnesota winters without incident. I just use the -50F stuff - when it gets cold, it'll turn to slush but very little expansion.
Lou C
If you get to zero F use -100! -50 gets hard at that temp I tested it in the freezer. Spend the extra $$$
Kosmofreeze
Fun Fact - Water is unique when it comes to common liquids in that it expands when frozen. This is what makes blocks crack. Even if your glycol or alcohol based antifreeze "gets hard" at below zero temps that doesn't mean that your block (or other components) are at risk of damage.
The coldest winter temp I've ever recorded at my house is -36F - never had a problem with the -50 stuff.
Lou C
And those PG antifreezes are ok for plastic piping but for an unyielding cast iron block you definitely want something that will stay liquid.
Ayuh,..... For that reason, I keep a 4" ssteel deckscrew on my intake manifold,......
It's always there when I need it, 'n I believe a zip-tie is much to limp,....
Air don't freeze,......
Find yerself a 350 Chevy long block, 'n you'll be all set for the future,....
Lou C
I have used West Marine -100 for years and when I can find it I buy Sierra PG coolant and mix it 50/50 with water. That gives freeze protection down to -26*F. I also tested it with the refractometer to be sure. The WM -100 tests to a freeze protection of -55*F. The -100 is a different rating for piping so that confuses people.
Lou C
Get one of those sets of small picks with the 90* tip I have dug out some old rust with it…
tpenfield
I'd go with a new (replacement) engine block. If the crack is on the outside, there is probably some damage (cracks) on the inside.
Lou C
They often crack in the cam valley inside which puts water in the oil.
You realize that draining the block and manifolds and refilling them with A-F is all that is sufficient to keep the block from freezing. Running on the muffs with A-f introduced, doesn't hardly do anything, right? It simply mixes the A-F with the block water, which then you drain and refill.
tpenfield
The problem (mis-conception) with the 'pink anti-freeze via the muffs' is that a portion of the incoming anti-freeze goes directly out to the risers and does not go through the engine block. Therefore . . .
-> only about 3 gallons of the 5 gallon jug go to the engine block (and manifolds)
. . . and . . .
-> the 3 gallons of Anti-freeze that makes in into the engine mixes with the water that is previously in the engine block and manifolds.
flashback
you may have short term success, time is relative. the jb will fall out eventually, especially as you can't get to the area to prep it properly.
. . . and . . .
Gee, the antifreeze does not go where expected. Can you trust that it gets the important parts?
If you want your block drained of water on a V6, pull the 4 or 6 plugs. Dump antifreeze into block thru all openings, which includes all hoses. Watch for it to emerge from the water intake grates on the gearcase and the manifold and block drains. You should see a-f in the water intakes, the idle water vents for idle, and thru the prop, plus thu the block and manifolds At that point you got it.
Lou C
Agreed, the suck it up via the outdrive method does not work because of the nature of raw water cooling. With a cold engine, the stat is closed, all the water from the impeller will exit the exhaust elbows. As the stat opens, some water will exit the engine, but the stat will rarely stay open all the way when the engine is on the water hose idling because it does not build enough heat in the cooling water to keep the stat fully open. So, you see AF exiting at the outdrive but that does not mean that ALL the water in the block exited and is replaced by AF.
The other issue as I have said before, these engine blocks (cast iron) were designed to be used with a pressurized cooling system with antifreeze with corrosion inhibitors. Using them as a raw water-cooled system results in rust flakes that can clog passages and drains, and also in shallow water silt, mud etc can cause the same problem. Cast iron and aluminum corrode differently, the way cast iron corrodes tends to clog cooling passages. Aluminum pits but does not shed flakes like cast iron.
