Should have been upgraded to alcohol resistant hoses like they recomended.The fuel lines on one of my Echos and my Husky saw melted from E10!
That is why the fuel you buy should be tested every so often as stations do not monitor there own fuel nor do they clean tanks and filters like they should be. Whenever I fill my boat, I always take a small fuel sample for testing. If contamination is found, I go right to the station mgr and show them. It has only happened a couple times over years if using them, but it can happen. At another station they have had issues with their non E fuels as they get little use and collect moisture and gum up often....you gotta test your fuel or put up with issues. About 8 years ago the local farmers created a co op fuel station for the locals to use. No problems since that was created even though I still test often. They go overboard keeping their tanks and filters clean. On top if that, they are about 30-40 cents per gallon cheaper! A second station just recently at the other side if the district so more locals can get trouble free fuel at better prices. Two of the top name fuel stations closed up.It's the same fuel and same gas station that is used for 3 cars and 5 outboard motors.
It's not a remote tank but rather the integral the tank on top of the motor.
I had 8 trouble-free years. The problem started last year. The carb was rebuilt last year, and was only run for 1/2 hour last year after the rebuild.
It's a 2016 motor, so it was built for ethylene.
Surprised Ohio doesn't have/enforce quality fuel and delivery standardsThat is why the fuel you buy should be tested every so often as stations do not monitor there own fuel nor do they clean tanks and filters like they should be. Whenever I fill my boat, I always take a small fuel sample for testing. If contamination is found, I go right to the station mgr and show them. It has only happened a couple times over years if using them, but it can happen. At another station they have had issues with their non E fuels as they get little use and collect moisture and gum up often....you gotta test your fuel or put up with issues. About 8 years ago the local farmers created a co op fuel station for the locals to use. No problems since that was created even though I still test often.
I only buy my E0 (non-oxy) from stations that I know sell a lot of the stuff. They get enough business so that the gas is replenished on a regular basis and is therefore fresher. Stations that don't sell a lot of it may also mix it with other fuels.A few years ago a Consumer Advocate group quietly did a survey of a number of different gas stations. They took samples and had a lab analyze them. E0 ranged from 0% ethanol up to about 10%. E10 ranged from 0% to about 15. It's obvious that you never know what you might get. I don't know if things have improved or not.
There are inspection officials that are supposed to inspect the fuel. Ohio is a main pass thru with the I 75 corridor and Turnpike. I am sure there are those that get away with certain things. I and others have shown our testing and filed complaints about contaminated fuels. With a monster trucking industry around here, I am sure there are ways to get around these tests if you know the correct people. We have shut down the two worst offenders, and the co-op stations welcome the testing. I am fortunate to live in the farm comunity that is willing to tackle and resolve these poor quality fuel issues. I can't say enough times, to check your fuel when purchasing it. Once a station knows that people are actually checking their fuel, they will begin to watch their fuel more closely.Surprised Ohio doesn't have/enforce quality fuel and delivery standards
"It's illegal to sell motor fuel that fails to meet quality standards. Penalties for not complying with the motor fuel inspection law and the stop sale order include a fine of up to $5,000 and/or one year in jail, a court ordered injunction prohibiting sale of the product and suspension of your registration"
Having worked as a Service Station attendant in high school, I can attest that the enforcement bureau takes their job very seriously
Dept of measure checks the actual volume, but here in Ohio the tanks are supposed to be inspected for contamination every so often. There are also some filters that are to be changed every so often. Stations can be fined if their fuel is contaminated. Better fuel stations do their own inspections and testing and many of the mist popular stations often skip over the testing and maintenence. Best thing is for private folks to do a little random testing themselves and report it if they find contamination. A few years back we were up north and filled our motor home with fuel. About a half hour later it was running terrible. Stopped at an auto parts store and grabbed a hose to sample some fuel in the tank. It was full of water ! After dropping 240 bucks on fuel, I was not a happy camper ! Auto parts folks helped us pump out about 10 gallons of water, then added about a half gallon of fuel dryer. And finally got it running. Limped on for 200 miles until I could add more clean fuel and dryer. Learned my lesson right there....whenever I buy fuel in larger quantities, I always take a small sample to test. Carry a couple clean baby food jars just for that purpose. In our travels we have found contaminated fuel in about 20% of the fuel we bought. Some station owners were helpful and others said to bad. We always reported to the franchise when bad fuel was found. Some sent gift cards while others did nothing. Here in my area, after a couple complaints they send out an inspector. I have saw a couple cases where the in ground tank had to be pumped out, fuel cleaned and then refill the tank with good fuel. That is very expensive to have done so they watch more closely after that. People just jump to E10 fuel being the problem, when it is the fuel your buying.What are the inspection officials looking for? I thought it was mainly for accuracy of volume.
In Maryland’s case, we are required by the EPA to use reformulated gas (RFG)What are the inspection officials looking for? I thought it was mainly for accuracy of volume.
