15hp gamefisher wiring diagram? model 225.581508
stackz
so I have a 15hp gamefisher. IIRC its a 1995 model. it had been in storage since basically new with 30hrs on it that were documented. I bought 5 years ago from an estate sale along with two other similar models. I mounted it, gave it fuel...it cranked up on 1st pull. so then I put it on a post between trees along with the other motors and an old 76 evinrude that needed LOTS of love from my grandpa's old 76 scout runabout.
had intentions to immediately restore the boat and use the gamefisher while fixing the evinrude.
but then life got in the way. finally got to the point where I'm having a professional restore the boat itself. I went to show him the motors and they were all full of carpenter ants....not actual nests...just ants running around inside the cowling...and some cockroaches. like seriously?
so I grabbed the 95 and tossed it on a post and vacuumed out the bugs and hooked it up but I cant get the primer bulb to get solid (I think it was deteriorating) and regardless of that...I couldnt get spark. I used two different inline plug testers and no spark. could bug crap have gotten up under the flywheel and just done weird things? its not points/coil. it is cdi as far as I know. at the same time. I dont want to tear the engine down without an actual diagram so I can chase thing issue properly vs just tearing apart an engine that should be good.
and yes...it still has excellent compression to the point I want to use a drill to turn the crank nut for testing purposes vs trying to yank on the pull cord.
I found the owners manual but that doesnt really help...https://www.scribd.com/document/703617318/gamefisher-225581508-owners-manual
for the kill switch. is it active if connected or does it ground the magneto if one of the wires is disconnected? basically for testing purposes if I pop the two wires going to the kill switch....will that give me spark...or if I effectively bypass the kill switch by unhooking it and hooking the two wires...would THAT give me spark? I'm just trying to eliminate variables as I troubleshoot this.
thoughts?
stackz
per this document it is indeed a force engine rebranded as a gamefisher per page 28...I guess mine is a 1996 so this manual is no good for my engine. ugh.
Nordin
The killswitch grounds out the CDI box.
Disconnect the wire from the CDI and should have spark if there is no another issue.
The maxrules site has old Chrysler and Force wiring diagrams.
Nordin
Chris1956, unfortunately maxrules only have diagrams for the lager 4 cylinder Force engine.
A lot of wiring diagrams for different engines are pretty similar. Maybe you can get an idea how yours is wired.
Are you sure it is a Force/Chrysler? A lot of the Gamefishers were Eska or Tecumseh, and some were Johnny's.
stackz
the model number on this one crosses to force so that is the direction I went in.
turns out the fuel line was dry rotted so the bulb couldnt keep prime. I put on a new bulb and new fuel line and bypassed the quick connect so the fuel line was hard lined to the carb and then after about 4 pulls it cranked up and runs now! yay!
however looks like I get to replace the water pump again as its not peeing.
stackz
ok! as as I said, I got it running. I know its been about 4 years since I last had it running but the water pump has seriously about 10 minutes of run time on it...as does the thermostat. yet...now that its running...I honestly cant remember if I have to wait for the thermostat to get up to temp before it pees or what? I only let it run for about a minute (to take the video) but I touched the head and it was pretty darn warm.
thoughts? should I take the t-stat out and see if it pees? should I just expect to pull the foot and swap out the water pump? I dont know what to do honestly....
Nordin
You need to have the engine deeper in the bucket.
The water pump impeller is not self priming, the impeller housing have to be under the water line.
stackz
but it is?? I mean if I put it on muffs the water intake is MUCH lower. what am I thinking about wrong? like I need to have it at least as deep as the impeller in the housing so it doesnt cavitate....ooohhhh I think I see now said the blind man.
I really hope I didnt cook that water pump impeller....I guess at this point it would be easiest to tell if I just take the thermostat out...fill the bucket ALL the way up...crank it up and see if it pumps? if it does...then toss the thermostat back in and see if it works properly. ugh....
I wasnt thinking. passive vs active water....of course muffs on pressurized hose forces water through the system....vs a bucket. or just being out on the water... duh. water pressure forces itself upwards and self primes the system...ughh....
