Unrealistic expectations for 71 20hp johnson?
jimmbo
Bman2895
So just an update. The motor was never quite getting full throttle. The bracket responsible for holding the throttle linkages and by that i mean the vertical shaft that meshes gears with the twist throttle. Was loose on the block. Screws loose and was missing one all together. I didn't notice it until I took the pull start off to fix it and then it moved. Now that it's tight its preforming exactly as I expect. That little bit of throttle i wasn't getting really made a difference on the take off.
saltchuckmatt
Excellent...time to go use it.
