So, interesting day.It's 500 degrees here in fl, no shade...on asphalt
1st- the boat has barley moved for the last six years...couple trips to the ramp (10 miles ), couple times home from storage to wash so it would look pretty sitting in storage. I always checked the temps on the hubs because I've been concerned about them. That wheel had been only 20 degrees hotter, trip home was 216 so that's the hottest temp it got and that was less than 5 miles. It was still full of grease.
So, I did grab another Kodiak 225 caliper. I just didn't have the time to deal with repairing. Perhaps I have one I can repair for spare, I'm guessing I can use it. Its just a casting, the piston rides on the seal, other than the seal there is nothing to wear right? I think i rebuilt them with a new piston, dust boot, and a seal in the bore. Only brakes I ever rebuilt like that. At that time I replaced the lines, bearings and the master cylinder. The master cylinder looks terrible. Fluid is cloudy, some kunk in the bottom of it. Seems like it's still functional but I guess not for long if I don't get it cleaned out. As I recognized from the first two wheels, pads were in order so as i went through each wheel I had the calipers off. I have a tool to compress the calipers for new pads, all the boots looked intact. All the bearings seem good, no rock in the wheel and they spun easily so I did not re adjust. Bled the brakes and back to storage. Hub temps are now all consistent, 112 plus or minus a few degrees. Feels like it is stopping better and not cluncking as bad. One of the 3 remaining calipers was a little hard to compress the piston so I will replace that next...the other two were ok but considering the fluid I just need to rotate them out and get that fluid out...
The master cylinder is still bubbling and brakes are holding and releasing...can I clean that out? The calipers have two fittings, the if I open them up i should be able to blow out the caliper? Blow out the lines from front to back?I can bring it home another weekend to make sure I recover all this fluid, disconect the master cylinder for cleaning ( with what ?) And blow out the lines...keep swapping out the cylinders...
I used 3 tubes of 14 oz Lucas marine grease. Was a little hard to find. The seals have a little grease coming out- that's goining to need fixing too but for right now I'm going to take today as a win and keep going . I have no trips planned and can work on cleaning the fiberglass and get these brakes a little straighter..
