Milky oil
SeaRayboater95
You really need a pressure gauge to accurately measure if the water passages hold pressure. A fuel pressure gauge will work.
I had a proper radiator test kit with a hand pump. Pump it up to 10lbs and I could see really small bubbles coming from under the tape. Took about 15 minutes to loose the 10 lbs.
Ken
SeaRayboater95
Maybe I'll cut that hose off above the hole and test again. I hope I can still get that hose. It needs to be replaced anyway. I didn't hear any air moving at all. I pumped it up a couple times.
Ken
Lou C
You’re in fresh water I’m thinking right? Has the exhaust ever been worked on?
SeaRayboater95
Yes, in fresh water. I dont think they have ever been off. Customer has doe zero maintenance since he has owned the boat. I replaced all the stuff listed earlier and was going to water test it when I discovered the milky oil. He is quite discouraged by the amount of money has spent already and is not happy about this problem. Want to be sure this is the problem and get this boat out of my shop! Lol
SeaRayboater95
Ok. I guess I'll cut that hose off and pressure test from there. Looks like it rubbed through on the water pump belt. The previous owner repaired it with tape. Thats the story my customer is sticking too! Lol
SeaRayboater95
Mornin' evrybody. Off to get some oil to fliush this motor. Is there a preferred grade to flush with. I would think a thinner grade like a OW20 or something would move through engine better. Thoughts?
Ken
For flushing find what ever is cheapest, your not going to put the motor under load so no issue. Do agree lower weight like 10w30, could use 0w20 but that's synthetic and probably cost more
SeaRayboater95
One more question for now. Do I need to remove those brand new exhaust flippers while running the engine for 30 seconds with no water? Hate to burn them up.
Ken
Scott06
Ken
super tech or rotella what ever is cheapest. you can drop 3 qts in and let it idle get a couple filters and gallons of oil.
Lou C
Ken
Well that's a gamble, I would though. If one falls down the Y pipe you'll wish you did.
SeaRayboater95
Ok, found something new. Pressurized cooling system again and can hear air moving in the intake through the carb. I guess pull intake first. Got oil and filters for flush, do I need to flush it first or how long can it wait? Would you still remove exhaust manifolds if intake is damaged?
Ken
nola mike
Ken
Guess it depends on how fast you can get a new manifold. if you flush with the engine running you're just going to end up with more water in there. Either drain and circulate like AD said or wait till you can get the manifold and then run it. Freshwater, and you've found a leak...I'd repair, pressure test again, and send it. Just wouldn't want it to sit all winter.
Lou C
Just a wild guess here but if pressuring the cooling passages puts air into the actual intake manifold air passages then I’m thinking more of a crack in the cyl head near an intake port. Don’t see how a problem with the intake manifold would cause this.
SeaRayboater95
Hmmmmm. Could it be as simple as a gasket? Well I guess I will flush it out because I wont be able to once I disassemble it. Customer may not want to spend the money once we figure out what it needs. At least its clean then and can sit for a bit if neccessary.
Ken
Lou C
I can’t see how even a leaky intake gasket would put air into the fuel/air passage in the manifold but I can see how a crack in a cyl head in a cooling passage right near the intake port (behind an intake valve) might. A head gasket, possible depending on how it blew. Problem is:
You’d have to pull off the exhaust; intake and heads; & take the heads to a machine shop to check for cracks. Was this boat ever overheated? Chevy small block heads do crack from bad overheats although the block usually survives.
If you have to justify the work you can start with the exhaust; if it’s good then you can make a case for going farther.
SeaRayboater95
Ok. Thanks. He said he never noticed it over heating. I'm not convince he even knows what that means. lol So, I would guess yes. So, do you think this is a secondary problem, or part of the milkshake problem? I was thinking head gasket right from the beginning, but I am by no means knowledgeable enough to say for sure.
Ken
Lou C
Water in the oil is just a symptom there are a number of causes in fact Mercruiser published a nice article on how to troubleshoot water in the oil. Depending on if it’s just water in the oil but not in the cyls, or it’s water in the oil and in the cylinders. If you have no oil in the cyls but water in the oil it’s not likely to be exhaust but possible a bad intake gasket, rotted intake water passage, blown head gasket(s) or cracked cyl heads or block.
Head gaskets on a cast iron Chevy small block don’t blow for no reason it’s usually overheating or a boat that’s running with too much prop pitch which overheats the combustion chambers. That or lean fuel mix both can cause it besides overheating.
Scott06
Ken
Fore you pull the intake do the pressure test with the spark plugs out you may have a bad head gasket That is leaking into a combustion chamber thru and open intake valve and out the intake .
I would at least pull the exhaust elbows and look in the manifolds for evidence de of leakage
