What you are saying is true however it seems difficult and will need additional effort and money and knowledgable peopleNothing is impossible.
Do you have a fuel gage if so you have a sender.Sorry what isa sender?
The fuel sender on top the tankSorry what isa sender?
I did that already and I will clean the tank from thereThe fuel sender on top the tank
Because it was never cleaned the last 10 years and the previous owner left some diesel for all these years in the tankwhat are you tryin to clean off?
Good idea! Thank youi've never cleaned a tank.
i did pick up a boat that had been in storage for 10+ years. I bought a couple dozen cheap inline fuel filters, put two on the fuel line. Filled up the tank and the varnish that had built up got softened and sloshed off the tank walls. When the filter captured i would replace every time it started bogging down on me. After about 10 filter changes it was all good until I sold about 6 years later - still had the last two filters.
ymmv
amazon has several scopes for cheap - they hook to your cell. No foam digging needed.What about the side panel if I want to check the condition of the pipe from the toilet?
Sorry I did not understand what Amazon has?amazon has several scopes for cheap - they hook to your cell. No foam digging needed.
And if something needs replacement do you have any ideas? The borescope is quite interesting idea!
Ok understoodi do not since i've not been on the boat - not great with looking at pics but i've had 40 year old boats that the poop chute was fine.
