1978 Islander 22 I/O
IslandExplorer
Wow, love the diamond plate and SS floor drains you added! They probably should have done that from the factory. That looks so clean. Might need a couple of those. Could rinse it right out if needed. Great work and thinking on that.
That under bench area is one of the louder in-cabin areas when anchored due to wave slap. Was on my Starchief at least anyways. I bet the choice to put foam in there will really help quiet it down when in there taking a nap on the hook.
66Holiday924
Exactly! I'm thinking about long-term care, ease of cleaning and replacing. The idea with the garage flooring is for it to be a disposable option. I'm not gluing it in. When it is junk, take up the deck fittings cut a new piece and put it down. There's nothing to rot under the flooring. It's aluminum framing and coosa.
The garage flooring is expanding and contracting. When it gets really hot I have a wrinkle... Nothing too bad. When I put the rest in, I'm going to put it in while it's hot and see how that helps that out.
I just figured that I have a whole cabin to use for storage. So, I took what storage I wanted out of the benches and used the opportunity to get an adequate amount of floatation foam in. Besides, in my experience, the under-bench storage isn't really that great. You end up putting stuff on the benches and have to move a bunch of stuff to get into it, and it ends up getting really dirty and grimy under there.
As I was doing it, I was thinking that it should help with sound. Aluminum boats can be loud.
66Holiday924
Port-a-potty flush handle access
66Holiday924
Floatation foam
When I did the demo on the boat I kept a huge hunk, about 2 cubic feet of styrofoam. I cut that up and incorporated it into my pour in expanding foam. I think it's cool when some of the original parts and materials can be put back to good use.
The last few pictures are of my bilge. I was looking to see if any foam "crept" in. Remember, I put down sheet vinyl across the ribs, so none of my expansion foam touches the hull. My thought is for water that makes it in through rivets that will inevitably leak, to give it a clear path to the bilge pump, instead of getting trapped and eventually rotting/waterlogging the foam.
I used HVAC tape to install the sheet vinyl. What an awesome friend it's been on this build! I advise anybody working on one of these boats to get a roll of that tape. It will come in handy here and there. If you're going to try the sheet vinyl in the bilge, it's the only way to go for installing that.
66Holiday924
More floatation foam work, I formed my rubber storage pails in the foam like I did my port-a-potty. The expanding floatation foam is very solid stuff. It can handle structural applications like this. You can see my sheet vinyl as before. I am not letting the foam form directly to the hull of the boat.
The port-a-potty is fitting really snug in since I added the foam for the rubber pail storage on the sides of it. I have the mounting kit installed, but it's not going anywhere.
66Holiday924
Check out what I found for $80 and some driving. It needs new fittings and I'm going to look into having the railing anodized.
66Holiday924
I added edge trim to finish my interior bench piece. I couldn't find trim the exact size I needed... This is 1/2" and my piece is 1/2" coosa with two layers of vinyl flooring. Nonetheless, it seems to be holding just fine and serves its purpose.
66Holiday924
I've been working on my seat platform for the past two weeks, as weather permitted. It's 1-1/2" Douglas Fir, Marine Ply that I bought as a sheet with that thickness from a shop. It'll provide a competent surface to mount my seats to. I have grade 8 hardware and I plan to through bolt my pedestals to it.
I did two coats of the Old Timer's Formula, and this is the only part of my decking that I'm planning on doing in the vinyl. The rest is going to be garage flooring.
It was interesting cutting through the 1-1/2" ply for the fuel tank access, which I think is necessary by law. Either way, it's a good idea to have. I used my attachment to make sure that I was drilling straight, drilled a small pilot hole all the way through and then used the pilot hole as a guide to line up the hole saw and cut from each side. I was delightfully shocked to see that it lined up perfect, creating a seamless hole.
With that dry fit, I think I'm ready to build my cabin bulkhead. Any suggestions for a door size on the cabin? I have 23" between my cabin benches so I'm thinking 21" over all is the most I'm going on the width for my door. what about height???
SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
I doubled my floor under the pedestals to get the 1.5" thickness. One of the guys on here suggested T bolts when doing the through bolts. Worked out well for me. As for the Grade 8 bolts, you wont be breaking those... lol
SHSU
66Holiday924
SHSU
It seems like the seats are usually one of the first things to give, either from rotted wood or inadequate hardware... It's not something I want to deal with happening, so I'm slapping Grade 8 in it and calling it a day!
66Holiday924
Installing some new skin on the gunnels. I reinforced the rear with coosa where I plan to mount fishing gear, downriggers, etc.
I took the rub rail off, addressed any loose or missing rivets, sanded loose paint & debris, cleaned everything up with acetone caulked around all the holes on the existing gunnel skin and down the edges and then riveted the new skin over the old, reinforcing the rear with coosa. I had to cut notches in the coosa where the rub rail bolts will come back through later.
66Holiday924
A few finishing touches in the cabin. I used gray tractor paint on the bulkheads. I like the way that machine paint goes on. It feels like it's adhering well and going to last.
This being a fishing boat, this cabin is purely utility, storage, port-a-potty, etc.
66Holiday924
Lookin good, I'd go :poop: in there :LOL:
@Watermann you're basically iboats royalty. It would be an absolute honor!
Dry-fitting some fittings and adding some finishing touches to my battery wells. I put some of my flooring in the battery holders protect from chaffing, add some cushion, and I thought it looks nice and happened to have the flooring to do it. One thing about the batteries being located further up front is that they will move a lot more.
Being a boat that I plan to take out on the Great Lakes, I'm going with two bilge pumps.
The fuel fill I decided to use is original to my 1966 Starcraft Holiday, which I think is kind of cool. I found myself looking for the same fitting and thought, why...
After getting the fuel fill and vent fittings dry-fit I felt confident that I should have nothing else to do under the decking in that area and could permanently install that piece of my decking. I countersunk the rivets so they will not be felt through my flooring.
66Holiday924
I've been very seriously considering painting the boat with the tractor paint, rolling it on. Where I used it inside the cabin came out pretty good. I had a run or two. The paint is heavy and it seems like no matter how long I waited, eventually it would run after I walked away to let it dry. So, anyway I tested that idea out on a surface that I don't care about, my upper bulkheads. The plan is for that area to be covered with cushions by the time I'm done, something comfortable to lean against if you're casting and retrieving.
I don't care for how it came out. I don't think it's impossible to ROLL paint the hull of one of these boats with tractor paint and have it come out pretty decent, but I've decided to ditch the idea, and shell out a few thousand to have it painted in a shop.
Actually, I tried Total Boat's, White, Aluminum boat paint first, and it went on so bad, that I tried the tractor paint over it, as the final coat. It's very likely that it would have come out a lot better if I used the tractor paint for the first coat. I still really liked Total Boat's two-part primer as a base coat to paint on but didn't care for their top-coat product. Anyway, like I said it's inconsequential on my boat because this surface is going to be covered.
IslandExplorer
Looking awesome, love how that cuddy area came out. The way that handle fits through the access hole is perfect. Wouldn't even know it was there otherwise, very nice. And I'm with ya on the seat stantions, Ive had numerous pedestal seat failures out on the water, one of which Im lucky I didn't brake my damn neck on the cooler that was on deck beside me. And Im only about 175lbs! Stronger the better. Some seats seem totally rigid and fine till you are suddenly in heavy seas and that is the worst possible time for a surprise failure and or injury. For me it was a violent side to side rocking from bigger boat wakes in a turbulent area I call the mixing bowl that ripped it out and slapped me down on the port deck. Pulled the big lag bolts right out of the dry, un rotted plywood. Just too much leverage at the base that they tend to make far too narrow of a diameter. These lighter, high reserve buoyancy tin boats can rock rather abruptly, esp side-on.
Hope when you paint it you keep the cool Starcraft spearpoint on the side. Have you decided on the hull paint scheme?
