Wood stove install
99yam40
I got to ask what is that thing above the stove at the ceiling in the pic?
and those windows seem to be not all straight for some reason.
if you go up in that corner the pipe above the roof will be tall to get above the peak of the roof to get to the 2 ft above the peak like you said.
"code says 2 feet above highest point."
tphoyt
Figured as much but you will likely need to be out another 18 to 24 inches when all said and done so you will have more room up top on the roof. Just a thought
redneck joe
In the cieling are storage bins hanging in the rafters.
Windows are off, the whole thing is whack. Verticals are pretty good need to work on horizontals.
redneck joe
starting to make progress on the shed.
Spent the day doing the small workbench. It is 20" oa and ~9 foot long but as you can see 3.5" are inset depth. The corner area is for a customer thing i'll show later.
redneck joe
starting the placement/design of the stove. I am going corner, up, then follow roof line to close to the peak, roof penetration not side.
Mc Tool
Hard to tell from the pic Joe but Id like that flue to be 600mm ( 2 feet ) from a non flammable wall
redneck joe
you are correct the pipe currently is about 10" off the wood surfaces but i still need to put up the concrete panels as the barrier. (our code is 18" or ~5500mm)
I will using square aluminum tube as a hollow spacer for the board to the wall studs. The 1/2" (150 mm) concrete board will do what it is supposed to, the aluminum tube will be the non-combustible spacer (and heat dissipater to attached underlying wood) and will have 3.5" (1065mm) of air gap over the requirements. Open at top and bottom for air flow.
Air gap requirement: To safely place a stovepipe or stove closer than the standard minimums, you must use a proper non-combustible wall protector (such as 24-gauge sheet metal or cement board) mounted with a 1-inch air gap using non-combustible spacers
Reduction limits: A properly ventilated non-combustible shield can typically reduce standard combustible clearances by up to 66%
So this puts me at 8-9" from wall to be compliant.
Feedback always welcome as i progress.
Mc Tool
:LOL: 5500mm ? huh , I thought you'd gone 0% Joe :ROFLMAO::ROFLMAO:
can almost do the conversions in my head. Been hard metric for most of my career.
I also can measure speed in furlongs per fortnight.
redneck joe
ok spent some time in the shed today (wife gone for a few) and the math wasn't mathing for me so going square to corner. With the concrete board installed i will be at least 10" off that.
