projects other than boats
A bit more progress......
4 steps forward, 1 step back
Adapter fits
Engine mount bracket design needs slight trimming
HTOB dimensions measures
Starter adapter plate needs some work as the LS4 block has some areas around the crank that were not shown on the LS3 block CAD model
So after 35 years finally replaced the brushes. It's a Craftsman Industrial (DeWalt)
The guys put new labels on it
you can not. it lasted at least 3 dozen car restorations and 4 boat restorations, some concrete grinding, and some really sketchy cut-off work while on a ladder 25 ft in the air.
I bought 2 sets of brushes. should outlast me.
tpenfield
I've been doing hardwood flooring (again). I did a bunch last year, now onto some more. This is wide-plank maple going into the bedrooms of the summer house. 2 down, 2 to go . . .
flashback
Have ya done any more with the fiat, just wondering how much time I need to allocate in order to see the finished product.
There is a whole build thread on Hotrodders
Great news. found the brinnelled bearing in the AR5 I pulled from the daily whip. so back to having a second trans for the Fiat project.
the OK news...... its a Toyota only Nachi bearing for the Aisin transmissions
the seal is a Toyota only NOK seal, however National Seal has a single interchange. this portion of the repair should be less than $100
still looking to get my hands on a new synchros
Scott06
is that engineered? would assume solid wood doesn"t go that wide? 2-3 years ago I did 5" Hickory solid wood. Cam out real nice but the wide planks were much harder to get to fit really tight vs thinner width floor I had done in the past. IF you haven't bought a jamb cut off saw it is a great investment if you keep doing flooring.
Stator is going to work?
may be able to get it to work if I can get a stable magnet assembly. at 7500 RPM, I think the magnets want to travel in a straight line vs the rotary motion.
tpenfield
I am trying to get the summer house more 'automated' so that when we are way things can be monitored.
I got the outside lights on automatic switches, along with a few of the inside lights on old-fashioned timers. I got the Ring doorbell and an Ecobee thermostat control. One thing that I have been missing is a water main monitoring system. I finally got the Moen Flo device installed . . .
I can monitor it from my cell phone, shut the water off/on as needed and set up alerts for unusual usage, leak detection, etc.
I felt a DIY install was not really in my wheelhouse, so I had a local plumber come and do it. The guy did a nice job with a by-pass line and a drain.
Add a wall-mount mechanical thermo-couple controlled valve space heater to basement or crawl space.
Set it at 50 degrees
If you loose power, as long as there is gas (natural or propane), it will keep your pipes and toilets from freezing .
tpenfield
My neighbor has an automatic generator (natural gas) . . . It ran for 5 days last winter when we lost power. I have contemplated the same, but the money has gone to some other priorities.
I did OK, last winter by hooking my portable generator up to the furnace.
