redneck joe
- Joined
- Mar 18, 2009
- 16,836
so you are not of this country given your usage of the metric system so not sure but here in the states about 1979 i think foam of some sort was required.
Ahhhhhh, yes mate. Good old country Victoria here in Australiaso you are not of this country given your usage of the metric system so not sure but here in the states about 1979 i think foam of some sort was required.
Hijack away lol.You won't see it until you start cutting i to the floor. The foam is in areas that aren't accessible through and lids or compartments.
Some pedestals have a center protrusion that requires a small hole cut out under them. The ones where the pole is part of the seat, and needs to slide down into the base. If you have that style, you would see the foam when you pull the base off.
Sorry, I derailed the thread a bit with my short guy talk. Luckily, I can just hide behind someone bigger until it blows over![]()
I should take great offence to that.......were it not truewell, you are Australian so no matter what that where you'd prob end up....
