Reinforcing bilge vent anchors and recommendation for 3" vent hose
ejnichol
One thing leads to another. Replacing dried and crush bilge vent hose required removing these 'fashion' vent fittings.
What kind of adhesive would you use to resecure these bolt bases? There glued on with some 2006 era marine construction adhesive that is failing but have only lost one.
Would you use t headed bolt to replace the missing end one. Secure with same adhesive as above?
Also what is a good quality 3" bilge vent hose?
Thanks.
ejnichol
I would scuff both pieces well and use a 2 part epoxy.
I'm thinking epoxy would get brittle quicker. My experience with two part epoxy leads me to believe they might fail after a few years.
3M Marine Adhesive Sealant 5200 might be an option.
Those vent are no longer available so don't want to lose them.
was probably plexus. that glue joint lasted longer than it was designed to.
ejnichol
Several owners of this era boat with this vent design reported having 'lost them' .
It would help if I knew what this vent was made of. The missing one I could probably replace with a toilet flange bolt I have on hand. Just need to determine what adhesive to use.
