One thing leads to another. Replacing dried and crush bilge vent hose required removing these 'fashion' vent fittings.
What kind of adhesive would you use to resecure these bolt bases? There glued on with some 2006 era marine construction adhesive that is failing but have only lost one.
Would you use t headed bolt to replace the missing end one. Secure with same adhesive as above?
Also what is a good quality 3" bilge vent hose?
Thanks.
Thanks.
