Thanks everyone! ‘84 115 TOP rebuild going!
ianmoore
Question on the throttle linkage. The throttle housing(2 pieces that hold the spring together) has some vertical play in it. I found this both times I have put it together and couldn't get rid of it. There is about 1/8" between the 2 pieces. I don't think it has any effect on the timing, but I wanted to see if anyone had run into this. Maybe this is fine and how they are.
Also, its a little confusing with the lower plastic washer. The linkage goes over the engine arm with the marking and into the throttle cam. The parts list shows the order of the parts, but doesn't show the engine arm, coming off the block, so its hard to know if that washer(#21) goes on top of the arm, or the cam.
I have tried it in both places, and i can't tell a difference with one seeming more in line with the rest of the linkage or not
how would you hook up an overheat alarm? Would it be off of the small partial hole by plug 1?
You could put a brass tee in the telltale hole in the cylinder head water jacket. One side of the tee would be the telltale elbow and hose and the other side of the tee would be an overheat sensor. You wire power from the ign key to the alarm (buzzer) and then to the sensor. When the motor overheats, the sensor ground to the tee, completing the circuit.
ianmoore
I like this idea. I could actually jump from the solenoid terminal for power. I’ll have to do some research on what I would need my temp to be. The weird thing is I have never even noticed my telltale water beyond warm. I think on my motor, my failure was not related to overheating, but rings getting thrown.
My telltale is on the block close to the CDI plates. There is also a PSI test point on the head cover, but I think mine is frozen up and I don’t want to deal with breaking it off
ianmoore
I just wanted to give yall an update as this was such a journey. When I found water in C4 after the rebuild and had to take the block back off again i was pretty bummed, and honestly starting to wonder if Id wasted a bunch of time and money on the motor.
Getting the new inner exhaust cover was key, and I think any future work on these kind of motors will use additional gasket maker material (of the right kind) to adjust for the minor flaws that happen on these old motors. I used permatex red on the exhaust side, and used Locktite 2244. I did a lot of research on different options for these bolts. The 2244 is a paste that creates a lot of the qualities of the epoxy and has a really good heat resistance, but is actually removable.
Timed motor to 6ATDC and 19BTDC and put it on the muffs. Every time before I would have to screw in the idle stop a good deal to have an idle that wouldn't die. I got advice years ago from an old Merc guy that this was just how these old motors were, and having 1000-1100 RPM was just how you had to run them. Hard on the lower units, but the best way...
Started motor on muffs and it ran so much smoother than it ever had.
We are entering our winter in the PNW. It is cold and rainy. I normally would have boat winterized by early October, but i launched yesterday in low 40 degree light rain.
Was amazed at how easily motor started. I actually had to pull idle stop in a bit past the mark to get 650-700 RPM. Was able to get a strong idle that went into gear without stalling or anything. Carbs were all set to 1 1/2. Didn't need to mess with them at all.
I am following the merc rebuild reccs, so didn't totally open her up, but the motor felt like a brand new motor in its torque and drive. Easily grabbing when i would hit the throttle. Supposed to cap the first outing at about 3500, but i had to hit 4k just to check it out.
I'm gonna try to take it out once more to open it up..Then gonna have to wait till spring.
Thanks again guys. Enormous help!
ianmoore
I do have a question-
I have rebuilt my carbs 3 times. I feel pretty confident with my rebuilds. Torqued exactly, tangs to spec. Tested them for holding pressure when closed. All my reeds are perfectly in spec.
When i am running the engine on muffs they carbs will leak a bit of gas from the throat. I don't see this when the engine is running under load with any RPMs. Is this just normal for these carbs when idling on muff?
I just cant find anything that would be faulty at this point. I am kind of assuming that the low load running just has extra fuel that doesnt get burned on the low RPM.
Do you guys find this with these engines? IT just seems be be running so well
Leaking carbs is not normal. Your fuel pump is pushing the fuel past the inlet needles or they are set wrong. You still have inlet needles and seats that are all metal?
Are you running the stock fuel pump? Is it figure-8 shaped or square?
ianmoore
Its the figure 8. The older model. Rebuilt and it is working as it should. The needles are the mercury needles and needle seat, and the tangs are set exactly(and shut all air/fuel). Floats float, and springs are exactly to stock. The thing that is confusing is that ive seen this with every carb rebuild, and that includes 2 seperate fuel bowl tops. I tried those 2 to see if there was anything in the metal part of the carbs
ianmoore
Is your fuel tank vent clear? Maybe a pressure build up in the fuel tank?
I have a permanent tank that i used for much of the time, but I am currently using an Atwood portable for testing and breaking in with new gas and 24:1 mix. So, Im having the same response with 2 tanks, and also, again, with full rebuilds on carbs. I won't say im an expert on the carbs, but at this point I feel pretty confident in that part of the engine, so its confusing.
The only other thing i can think of is that I'm priming too hard with the initial bulb prime.
Mc Tool
Some two strokes will do this ,its called puddling ,where fuel either falls out of suspension or doesnt fully atomise in the 1st place at low air flow and is not carried into the motor . If your motor maintains a steady idle and gets on with it when you apply throttle its not flooding . The cure is to not look at it 😁
You may be able to alleviate it a bit by closing the idle/low speed mixture screw , or messing with low speed jets and air correctors but that probly isnt worth the trouble
ianmoore
This is kind of what i am thinking. The motor runs so well and i know the carbs are set up correctly.. I just want to be thorough with the engine after putting so much time in the rebuild
Mc Tool
The only other thing I can think of ....if you removed the throttle butterfly discs off the throttle spindle...did you get them back on the right way round. There may be a section of the butterfly disc circumference that has been thinned down ...if so this part should be facing the motor and be adjacent to the transition orifices in the carb body .
ianmoore
I have rebuilt carbs a few times. It is a possibility, but i remember when i did it last time that i messed with the butterflies to see if they sat better in the other direction. I did that with the understanding of how i had them before. I found that the way i had them sat correctly in the carbs and closed against the walls at idle.
I appreciate the suggestion, and will look again, but i feel pretty confident that they are in correctly
