martygry7162
- Joined
- Mar 22, 2004
- 115
hey boaters, i'm new to boats and have no engine experiance good with hands but engines get tricky. but i'm going to give it a shot <br />as i said the engine won't start so i would like to go through the troubleshooting steps one at a time and if you could please fill-in or correct me where ever need be<br />ok first heres the picture i have a charged battery and a full tank of fuel. using the FAQ post (engine wont start) as i guide to doing this.<br />step 1 <br />starter engages and the flywheel rotates at a good speed.<br />step 2 was where i need further handholding <br />when i crank her over she does all but start i crank her for 10-12 seconds then it puffs out a small white cloud of smoke and dies.<br />needless to say i was disappointed with this and move on to check the fuel flow the manual says to disconnect the fuel line at the carb and see if fuel flows freely when the primer bulb is squeezed. can this test also be done by disconnecting the fuel line and pumping the primer or do i have to disconnect at the carb i tested the fuel line and fuel flows freely from the line.i did not do this test from the carb.<br />she ran well proir to it not running so i'm hoping theres just some small thing i've missed.......... sorry i gotta stop here the babys up and i gotta tend to his needs hahaha anything you can add would be great and i'll be back to add other steps i've taken as well as to see what advise you have
