Re: 89 rude 40hp o/b wont (electric START)????
Marty, Let me just say that the pack being at fault is just a guess. It could be the stator, trigger, kill circuit or a number of things. To go through all of these things will require a Manual and some special test equipment. I would get a Manual and read it well at this point. Have you tried all the tests I have suggested so far? Many of these I have not recieved answers on, so it's hard to tell what we have and have not. This appears to be an intermittant problem and those are the hardest to diagnois. The main and only question right now is: Are you getting spark to the plugs with a fully charged battery? As one very respected member posted on this subject a while back said:<br /><br />>first, try disconnecting the kill wire at the packs.(black/yellow) if you have a grounded kill circuit, you'll have no spark.<br />>then check all grounds, plugs and harnesses for breaks, corrosion and tightness.<br />>try for spark with rectifier or regulator disconnected<br />>then check the charge stator voltage<br />>then check the trigger voltage<br />>if all above checks OK, suspect the packs<br /><br />Best I can do right now... <br /><br />And yes, that is the powerpack, but they are expensive and I don't want to see you spend unnessesary money if it's something else. Also, this might be a good time to start a new post titled " Motor will not start" and explain what happened and is happening now. No need to get into the specifics. You may get more opinions this way. Normally the moderators want you to stay with the same post, but in this case, I think it's time to start over...
