colud a tune up solve my problems
redsxhater04
i have a 2.3 evinrude and i am wondering if a tune u would be a good idea to solve some simple problems. these problems are is that when i accelerate to top speed the motor dies and 2 the motor runs only with the choke open. sadly i just got the motor two days ago. its used
redsxhater04
Re: colud a tune up solve my problems
that sounds right but do u have any idea on why i cant run with the choke closed or should i just clean the carb and it should all work out
oregonducker
Needing to choke it to run is a sign that the carb is fouled up. Fuel delivery to the carb could also be the culprit. Dieing at full throttle and needing to be choked at all times means it's starving for fuel. Check the fuel lines (make sure they're clear) and clean the carb.<br />If this motor handn't been used for awhile before you got it or if you don't know it's history definately do all the stuff listed in that link I gave you. Very important. You don't want to get it running right only to have the water pump crap out on you and turn your motor into an anchor.
redsxhater04
thanks after solving this problem i will be sure to go to the dealers because he said it was ready to go but obviously not. should i also get this tunned too?.
oregonducker
Cleaned carb, new water pump, new spark plugs and new lower unit oil are the basics when I get ahold of a used motor. If it runs great after all that then be happy and take care of it.
redsxhater04
would u have any idea at what oil ratio to use and a reccomended oil to use.<br />thanks
Goodoleboy
Whats your model number.<br /><br />Good luck!
redsxhater04
Goodoleboy <br /> just got news from my dealer that its a 20-1 ratio what kind of motor oil do u reccomend it is also a 2cycle motor i will have the model number hopefully latest by monday
Goodoleboy
Gota have the nodel number before we stick our necks out here.<br /><br />20 to 1 dont sound right for any motor no matter how old.<br /><br />Good luck!
MCM
Hi,<br /><br />Maybe I'm misreading this but you said the motor only runs with the choke open and that it wont run with the choke closed :rolleyes: <br /><br />The choke is supposed to be open in order for it to run at anything past just warming it up.<br /><br />Was this a typo?<br /><br />Mike :)
redsxhater04
MCM> i was told that the choke is supposed to be closed after it warms up is this true?<br /><br />but the problem is is that after it warms up i will close the choke and it then will loss power and then die.<br /><br />with teh choke open i loose an incredible amount of gas. maybe half a tank in 5-10 minutes but this motor has a small built in tank.
MCM
If the choke is closed the motor is being starved for air, the fact that it wont run with it closed would be expected <br /><br />Some people use the choke to stop the motor in place of a kill switch,<br /><br />Give it a try open, like you said the only time it runs is when its open,<br /><br />Then find the person who told you that & use the for the anchor :D <br /><br />Mike
redsxhater04
MCM> my other other reason is why does it take so much gas?<br /><br />people tell me that it is because the choke is always open? is this true? now im really confused.<br /><br />for info this is a 2.3 evinrude motor<br /><br />do you need a model numner and serial number?<br /><br />steve
MCM
Model & serial# would be good<br /><br />How much gas could a 2.3 use?<br /><br />Mike :)
redsxhater04
ok i will get back to you in a little while i have to go look at that and maybe i can get a picture of the gas tank.<br />thanks much steve.
redsxhater04
ok guys srry for the holdup<br />the serial is h9256367<br /><br />the model is hetreic
redsxhater04
can i please get the year and the oil ratio for this model<br /><br />steve
Paul Moir
Could it be H2REIC, 1991? Anyway, if it was make after 1963 then the fuel oil mix is 50:1 with TC-W3 outboard oil. That's 1 pint of oil for 6 gallons of gas if you talk amerispeak, 20ml per litre of fuel for the rest of the world. 87 octane (91 RON) gas is usually what you want.
steamboatwilly
MCM got it right.That motor will not run with the choke CLOSED.Only close the choke to cold-start it.when it warms-up open the choke.If you are trying to run with choke closed,it will burn a lot more gas.(Again,Like MCM said, whomever said that would make a really good anchor).
