Aluminum to stainless prop; lost WOT rpm
Hooty
Re: Aluminum to stainless prop; lost WOT rpm
You could install a jack plate but that's probably too much trouble. ;) <br /><br />c/6<br />Hooty
agrazela
Hooty,<br /><br />I considered a jack plate, but I did not want to place the center of gravity of this boat any further astern than it already is, either through added weight or through distance behind the transom.
snappernz
have you tried a permatrim on the motor
agrazela
Update:<br /><br />I got the boat to the water. After fiddling a bit with trim, I am now up to 4800 rpm, 31-33mph (by GPS). This is an improvement, but still not yet up to recommended WOT range of 5000-5500.<br /><br />I can maybe go another 3/4" higher on x-dimension before I run out of transom to clamp on to. Might I expect to get 400+ rpm from this move?<br /><br />I cannot add a permatrim (or other hydrofoil) because of the location of my kicker...with both motors down, the kicker prop would nick the hydrofoil.<br /><br />If raising the motor again does not work, I may consider having a prop shop remove cup from prop. Again I ask, how much might I expect to pay for this service?
