Hello all!!<br />Well I finaly got around to opening up the free merc 1150 tower of power I got last year
<br />The serial number is 7097386 I believe it is from the mid seventies but I am not sure?<br />Anyways other than being sun faded the motor looks to be in good shape not much corosion or any signs of over heating. When I removed the plugs they all looked pretty good except 1 & 2 were pretty carboned up. Next the compression tests ...
jug one shows only 60psi and jug 3 only 90 psi the rest are all around 130 psi. I tilted the motor up and gave the 2 problem jugs a good dose of Deep Creep and gave them a good workout to work in the oil then I even put a vibrator on the motor(old fish pump) overnight. Well jug 3 came up to about 105 but #1 didnt budge from 60psi
<br />So onto the overhaul... I am pretty handy with the wrenches and have worked on quite a few 2 strokes but never a big ol beast like this!
So this is my plan of attack and I hope that one of you ol vets will chirp in with any advice
<br />Its always nice to have the parts on hand when you start the tear down so these are the parts I plan on ordering before I start the tear down please let me know what ya all think:<br />General<br />1. Carb kit for each carb.<br />2. Fuel pump kit<br />3. new hoses clamps ect..<br />4. water pump kit<br />5. Looking for a flywheel puller cheap!
<br /><br />PowerHead<br />1. new set of rings for each piston<br />2. <br /><br />Questions<br />What about the reads in these old monsters? Is it a good idea to replace them while I have it open?<br />There are probly a lot of gaskets that need replacing and I wonder if there is a complete power head gasket kit?, Oil seals on the crank?<br />I bet its going to be a real **** to get all those rings started in the block, any tricks??
<br />What about the conecting rod and crank bearings, are these built to last or should I change them too? I guess the big question is are these parts readily available?<br /><br />I just got my self a seloc manuel and will start doing some reading tonite and see what I can come up with. The motor was basicly free so I dont mind spending a few bucks on her to make her reliable again.
<br />Thanks in advance to any and all that comment <br />Sincerely Jon
