- Joined
- Jul 23, 2011
- 51,424
I use sturdy built trailer (they have a local store)
haha. Right!? I know. It was a while, obviously. I'll never neglect that chore again.Sorry, got to ask the obvious…..how long since you last serviced the bearings?
That amount of corrosion didn’t happen overnight
New axle doesn't have to come from ez loader. Just need to get the measurements right.
$360 complete with hubs and bearings.
And free delivery to Kalispel by Aug 7th.
Many options available.
Shop around and call their customer service people to make sure you get the right/good stuff.
We stop every 100 miles. I walk around and check bearing temp, look for grease spatters on the back of the tires and check the tires.yikes! my greatest fear on the road coming true. I stay so paranoid about my bearings and tires its way overkill.
I not far behind you at all in this department. I check my tires and bearing before EVERY trip. My boat ramp is about 10 minute drive and I don't even want to have any problems that close to the house. I will venture about an hour away at the most. I have a small son that goes out with me often. Letting preventable issues happen (such as a bearing failing) is not optional for me.We stop every 100 miles. I walk around and check bearing temp, look for grease spatters on the back of the tires and check the tires.
I would not do that with a car, but boat trailers are notorious for problems. The ONLY issue I EVER had on the highway was with bad tires, even though they were new and properly inflated.
You can call that overkill if you want, but having a trouble-free vacation is not "nice", but rather mandatory. Besides, the ladies like the pee break.
41,000 peeps died on the road ? .......yeah ? How many got shot ?In 2023 41,000 people killed in auto crashes,
Hopeless attitude.
Firearm deaths in 2023 were 18,874. That does not include suicides, which of course were not accidental.41,000 peeps died on the road ? .......yeah ? How many got shot ?![]()
I think most of the troublesome peeps are aware of the risks that are there and the ones their behaviour makes worse but the ole " wont happen to me " mind set rolls in often coupled with the "never did care about anyone other than me anyhow ". As a motorcyclist for decades I have learnt to treat all others on the road as idiots ........paid off countless times .Firearm deaths in 2023 were 18,874. That does not include suicides, which of course were not accidental.
Of the 41,000 auto deaths, how many were due to improper auto maintenance, texting or from drunk driving? THOSE conditions are due to irresponsibility, which isn't really accidental either!
I do the same as you but I also check the hub temperatures with an infrared thermometer. It saved me once when the hubs looked fine but the temp on one side was way higher than the other side. I was at a rest stop and replaced the bearings on the spot.We stop every 100 miles. I walk around and check bearing temp, look for grease spatters on the back of the tires and check the tires.
I rode all thru High School and College. My Sweetie went along with me many times. After our Engagement, 2 things happened.As a motorcyclist for decades I have learnt to treat all others on the road as idiots ........paid off countless times .![]()
