I/O (Sterndrive) Conversion to Outboards
alldodge
Wonder how many less pages this thread would be with out all the what ever this is.............
It started off as an in depth look into what it will take to change from I/O to OB. Who ever looks at it now/later will mostly see what ever sticks on the wall and not so much as the real work it took to make it happen
tpenfield
Wee bit, goop, and bog. Those are the terms that will come out of this project
Pmt133
Wait... I thought goop was goop? :LOL:
Kidding aside, there is more complex thought in the last 10 posts than my entire engineering department at work is capable of...
where did this term bog come from. never heard that used.
Australian and British car guys called it bog starting about 70 years ago .....It's also the term for the toilet or crapper. Because well.....2-part fillers have the consistency of cow dung
tpenfield
Flatness has been achieved . . .
I mixed up the goop (assorted fiberglass stands, VE resin, adhesive filler) and used the 1" Coosa pieces to form a flat surface. Clamped in place and heated for curing.
I'll need to do some finishing/fairing around the edges. but the engine mount surfaces are flat.
redneck joe
Remind me again, what will cover the holes up top or are you just taking bets on broken ankles?
tpenfield
I tried my hand at the VE fairing compound . . . It is a work in progress.
I'm not sure I have the patience to do fairing compound, but we'll see.
I got a final reading on the transom thickness, now that I have given them flatness.
IMG_9391.JPG.
No worries there . . . I just wouldn't want to be the one who has to drill the mounting studs . . . :ROFLMAO:
redneck joe
Whenever my brother and I do a project, especially as a team, we cackle about the poor son of a b that will have to undo or work thru it. Unfortunately we both have reworked our own work and we call each other and b,tch about it.
Could always have the admiral help you. Didn't she do bathroom remodeling earlier this year.
It's just like mudding drywall
tpenfield
I did some cutting of the transom today . . . Went through a bunch of saw blades, metal cutting and carbide for the most part.
The transom is 2.00 " thick
about 1.5" foam core
0.4" fiberglass outer skin
0.1" fiberglass inner skin
I got to see if I can get some more blades tomorrow to do the other side.
tpenfield
Transom holes are done.
I also drilled the drainage holes that will let bilge water flow to the extension bracket where there will be a garboard plug.
The 4 holes on the underside of the swim deck are next . . . but . . . there is a vent tube in the way. That will be tomorrow's project, after we deal with car fixing. The Admiral's car is going in for a recall and my car is getting 4 new tires as per my flat tire post from last Friday.
