R racerone Supreme Mariner Joined Dec 28, 2013 Messages 39,723 Today at 1:49 PM #22 Checked reed valves ?
jimmbo Supreme Mariner Joined May 24, 2004 Messages 14,409 Today at 2:09 PM #23 Well within the 15% Tolerance of each other, however some will say the Numbers are low
C cpdupont68 Cadet Joined Jun 29, 2026 Messages 14 Today at 2:14 PM #24 I racerone said: Checked reed valves ? Click to expand... I don't really see any of the typical indicators of a Reed Valve problem. • Hard starting • Erratic idling • Unburned fuel spitting back out of the carburetor
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 39,723 Today at 2:46 PM #25 Revisit the fuel pump.-----Location of UP marking.-----Dome spring location relative to outlet nipple.----Check valves in the pump.
kbait Commander Joined Nov 13, 2007 Messages 2,486 Today at 3:25 PM #26 Metal fuel tank? Connector on tank itself can leak air when the o-ring behind the little metal pin(fuel side) doesn’t seal..
