1976 Evinrude 9.9
jimmbo
Well within the 15% Tolerance of each other, however some will say the Numbers are low
Revisit the fuel pump.-----Location of UP marking.-----Dome spring location relative to outlet nipple.----Check valves in the pump.
kbait
Metal fuel tank? Connector on tank itself can leak air when the o-ring behind the little metal pin(fuel side) doesn’t seal..
