rickycobble
- Joined
- Sep 13, 2016
- 28
This is a 2004 Johnson 115 hp. I have not looked terribly hard, but when boat is running, I can see water coming out from the front of the engine, just under the engine cover. I took the cover off with the motor running and the water is not inside the compartment. It is coming from somewhere not too easily to see just below the main cover. Water is coming out of the pee hole on the back side of the engine. Below should be a video. What are some things to check? Thank you
