frustratedboater
- Joined
- Jul 10, 2007
- 489
Good evening,
I have my old '04 Yamaha F225 hp 4-stroke that I'm converting from a 30" shaft to a 25" for a friend that is buying it. I have to change out the mid-section shift rod and the powerhead has to be pulled. While I'm in there I am changing out the oil pump and wanted to provide a list of items that I'm getting, but not sure if ther's anything else you'd recommend since I'm in there. My plan so far will be just lifting the powerhead and replacing the pump/o-rings and powerhead base gasket...
On the list to order:
-Upper casing gasket- 69J-45113-10
-Oil pump assy.- 69J-15312-01
-O-rings (for pump (2)- 93210-25552-00
Is there anything else that I may be missing or you recommend that I service? I hate to wait for 1-1/2 weeks, just to find out that I needed something else. I appreciate any incite..
Just thought of something else..., would it be cheaper to rebuild the pump with the seals, etc rather than buy a new one? Thanks
