crappieslab
Thread starter- Joined
- Apr 22, 2006
- 8
My 200 has a miss at idle in neutral and in forward, in rorward the idle jumps up causing the boat to surge. I've replaced the plugs and ran a full tank thru it and pulled them again and noticed that #2 cyls plug is black half the way around the porceline and the other half is white/light tan. And the other plugs (1,3,4,5and6)are white/tan all the way around the porceline. I've checked the fuel/air pressure-ok,compression-ok,put a new plug in, swapped direct injector and put new fuel injector in replaced tracker diaphram, new coil, swapped coildriver and still have a problem. Along with the plug being black I can pull the plug on #2 coil and the motor smothens out and when I pull the plugs on the other coils (1,3,4,5,and6) the motor gets rougher. ANY IDEAS OR HELP? Thanks
