'05 Merc 60HP Bigfoot 2 Stroke: Coolant Water LOW PRESSURE ??
SunTrackerPB21
My OB has developed a ticking sound and I'm wondering if it might be the Impeller.
I ve searched these forums (AND the owners manual) but can't find:
A chart showing the motor RPM VS (what might be the expected) water flow at that RPM or MINIMUM suggested water pressure.
For example, my OB goes like this:
2000 RPM (nice easy cruise speed for a Pontoon boat) Water gauge reads: 6
3000 RPM " " 10
4400 RPM " " 15
5200 is WOT
On the face of the gauge, there are TWO ARROWS facing each other at the TOP -> <- and putting the needle between the arrows= 15
Water always comes out the "indicator" hole but I'm wondering if "6" is too low and if the impeller might need replacing?
Alan
Sunfish12
Re: '05 Merc 60HP Bigfoot 2 Stroke: Coolant Water LOW PRESSURE ??
If there is ever a question as to the impeller just change it. When was it changed last? I don't know if there's a chart. If your not overheating or getting an alarm it can't be to bad.
SunTrackerPB21
Impeller... When was it changed last?...
Its never been changed. Motor is 5 yrs old but probably has less than 100 hrs. I guess it could be "time for a change" anyway.
