05 mercury 90
BOAT DOCTOR
should i use lock tight on the new rod bolts.30 foot pounds.so when the torque wrench shows 30 foot pounds and then turn the torque wrench another 90 degrees or do i have to buy a special wrench
Faztbullet
Re: 05 mercury 90
First you cannot reuse your rodbolts you need NEW. The torque is 30ft lbs plus 90 degrees
BOAT DOCTOR
Re: 05 mercury 90
:confused:
Faztbullet
Re: 05 mercury 90
Sorry did see the "new"(winterizng all day). The rodbolts go on with drop of oil on threads(no loctite) and torque in 3 steps 10-20-30 and manual says to turn a additional 90 degrees. I use a torque angle wrench because the V-6 use it and I know its a true 90 degrees when torqued. Or you can torque to 30 then take it up to 35 as that about where 90 degrees put it at.
