1.7DTi Using 15Liter Diesel in 5min... HOW ??
nicolajjr
Hi Guys
Please help, i have 2 1.7Dti engines, they have not been startet for 2 years, but they starts very well and have a nice sound.
But!
They have a problem there is a bit expensive! It will make a 7.4 Big block jelouse ! :)
When i start the engines one by one, the engines are using a lot of fuel
10-15L Diesel in 4-5min a idle 2-3min at 1800-2000RPM
Does my diesel pumps need rebuild or what can it be?
right engine: Does not smoke
Left engine, smokes a bit.
Re: 1.7DTi Using 15Liter Diesel in 5min... HOW ??
Ayuh,... Welcome Aboard,.... If they've got mechanical primary fuel pumps,..??
Is the sump oil level Risin',..??
Don S
It's a diesel. You are only measuring the fuel coming from the tank to the pump, you have a return line from the pump that goes back to the tank.
nicolajjr
Hi
Its mechanic pumps.
But Don is it possible for the engines to make such a big vacum ?
Don S
It's normal circulation.
Put the return line into your container and the level won't noticeably drop.
Do you have a problem or just playing with it?
