Aquasport19.6
- Joined
- Aug 31, 2005
- 52
My 115 Evinrude (year approx 1983) will not turn now. I say now because it was turning just fine when i bought is about 3 weeks ago. I recently took my boat out for a test run to see how things were running. I started off slowly and noticed that the engine has little bit of a sputer in it. i took the rpms up some then it ran fine. i then took it back down and notice it doing better i then took it into about 4 1/2 feet of water and the engine staled out i started it back up again thinking it may be two shallow for the engine it then stalled out again and i had to get a tow back in becasue it would not turn over. I found a small gas leak in the line leaving the fuel pump. and fixed it. i then started it up bye having my wife start the engine and myself pulling it by rope. the boat started right up and i turned it off the next day i did the same thing and it would not start, and the fly wheel would not even turn. i am wondering if i am going to half to get a pully an take the fly wheel off or if there if i flooded the engine and need to take the spark plugs off and try and turn it. any help will work <br />thanks
