AAWhaler
Thread starter- Joined
- Jul 2, 2009
- 4
I have unmarked battery cables on my c.1986 mercury 115 hp. I accidently hooked the cables up wrong and tried to start the motor. I did not realize that the cables were hooked up wrong and thought that the "clutch" that engages the starter gear was stuck. So after trying it a few more times I unhooked the cables oiled the top of the starter motor shaft and hooked them up again the wrong way. Finally realizing the problem I tried it the other way and the motor turned right over. During this entire time there was no smoke, sizzling, popping, or anything else that signaled anything wrong with the set-up, except the starter motor wouldn't engage (Because it was spinning the wrong way). What should I check for? Is the CDI box ruined? What else might be destroyed from my ignorance?
