115 v4 vro
T-23
hello, question have a 115 v4 vro it fired up and ran for a couple min. then i heard a buzz come from the throttle box and it shut off, now it wont start. still water trying to shoot out of spout so i dont think it is the water pump but i could be wrong.
bktheking
Re: 115 v4 vro
Check the temp of the engine with your hand, if you can't hold it for more than 2 seconds on it you be cookin your motor!
T-23
Re: 115 v4 vro
cool thanks, it was smokin hot when i touched it. i think it may be lower unit.
ezeke
Re: 115 v4 vro
The tell-tale will let you know if the water pump is working, but not whether or not the water is passing through the cooling circuit of the engine.
Check your cylinder head gaskets for damage. Cause could be cooling circuit or VRO; what was the horn signal, constant or intermittent beeps or some of both?
Check your thermostats and the water deflectors.
T-23
Re: 115 v4 vro
it was a short buzz then stopped. i turned off motor then tried starting and it was a constant buzz everytime i would turn key
bktheking
Re: 115 v4 vro
Could be several things, water pump is bad, blockage in the system, thermostat not opening, running it with no water, water pickup blocked.
Correction, saw from your post it is peeing from the telltale, that means it's pumping water. Pull the thermostats and inspect them, what year motor is it?
Model # would help.
ezeke
Re: 115 v4 vro
It's good standard shop practice to replace the cylinder head gaskets after an overheat. In the meantime, get some extra oil to the cylinders/pistons in case there has been water intrusion.
Also, visually check your ignition components for heat damage.
What is your model number?
T-23
Re: 115 v4 vro
got it!! it was the thermostats, i put them in a pot of water and boiled them at 145degrees they did not open. easy cheap fix...for once. Thanks for the help
ezeke
Re: 115 v4 vro
Good, but you still have to fix the head gaskets or at least check the compression.
bktheking
Re: 115 v4 vro
Ya as ezeke said, do comp test now that it's been overheated, at least you caught it in time, it's probably ok.
