115hp V4 - how well will run run with 60psi on one cylinder?
BigB9000
just like the title says.
one of the cylinders is down to 60
boat shop dude said it'll never run well with that 'dead leg'
bigpoppakdog
Re: 115hp V4 - how well will run run with 60psi on one cylinder?
had a 140 hp chrysler than had a shot cylinder. Had no hole shot, but once the boat got some speed she kicked in. Probably ran like a 70 horse or so.
JB
What were the other three, BigB? The indication that a cylinder is bad is the difference from the others, not measured psi.
BigB9000
left:
110
90
right:
115
60
emdsapmgr
You have two cylinders below the 10% guideline. When compression gets low, the crankcase suction also is affected. With low crankcase suction, you don't draw as much fuel/oil through the carb. This can cause a lean condition and possibly scuff the piston over time. It's time to decide if you want to tear it down and fix it or get a replacement.
kenmyfam
With those numbers not very well.
F_R
Honorary Supreme Mariner
Keep running it and it will get worse till something breaks. Then you will have 30psi. You are already heading in that direction.
SKEETR
Headed for a new block quickly. The cylinders will be unserviceable running a piston with partial rings.
BigB9000
ah.... new outboard. Gotcha.
I found a dude localy that has an 81 with power trim/tilt.
and the records from its recent rebuild.
I'll bolt it onto the boat and see what happens
cdoliver
do a decarb on the motor with 60psi and see if it has a stuck ring/ carbon buildup
