120 hp Johnson starter won't connect with flywheel
Eddie13
Yes.
However, while I was turning the starter to answer this question, the bendix actually engaged the flywheel and I got it started for a few seconds. It is on a trailer and I didn't want to run it too long out of the water.
Grease the bendix good they do get stuck..
cyclops222
If your engine needs more than a few seconds of cranking every start. Then the starter starts to cycle a lot ang heat up over time . Drying out the grease.
It is difficult to save money by not keeping the engine in perfect tune up.
Texhunt
Yes.
It seems that the main problem was the battery not being totally charged. I do have one additional question, some of the activities that I will use this boat is trolling for sand bass, I usually troll threw the schools of fish with a deep diving lure that goes down 10-15 feet. I am wondering if I troll for an extended period of time, will the battery still charge as it should? My greatest fear now is getting stuck out on the lake and the bendix doesn't work. I have a spare battery that I can take with me,along with cables for a jump. Will that work? Any ideas?
Crosbyman
Just give it a good run every 30-45 minutes of trolling to generate some stronger current to charge the battery . You can always brings a NOCO booster pack to get you going. I boosted an old Evinrude V4 with a NOCO 1000 amps booster. Hard to believe but these small packs can start car engines, diesels etc.. in winter !!
The GB40 is a portable lithium-ion battery jump starter pack that delivers 1,000-amps for jump starting a dead battery in seconds. Designed for a car, boat, RV, truck and more with gas engines up to 6 liters, and diesel engines up to 3 liters. Our most advanced car battery charger jump starter ever. Featuring high-discharge lithium technology for safe operation in any climate. A rugged and water-resistant enclosure rated at IP65. A rubberized over-molded casing to prevent scratching or marring of surfaces. And an ultra-compact and lightweight design weighing just 2.4 pounds.
Buy a new marine starter battery !----Post #2 and #12 mention BATTERY to you.
