Re: 12V powerloss?
The determining factor is going to be the length of the wire run from the battery to the winch .
2-0 MINIMUM if under 8' , up to 0-0 if longer .
Check out your welding supply store for the wire and terminal lugs .
BTW , you should consider a high output alternator and a dual battery setup if you are going to do any prolonged winching .
Also , invest in an accesory kit for that winch , including a "snatch block"(doubles the pulling power and reduces the load on the winch , 2:1 mechanical advantage) and winch line blanket (helps keep the cable down if it snaps..) .
Some winching advice :
Put the hood up to help prevent the line/hook going through your cab if the line breaks .
Set your ebrake .
Chock your wheels .
Keep your engine running , high idle if possible .
NEVER hook to steering or suspension parts , frame members or tow points ONLY .
Do not use chains .
Stand to the side of the winch line , as far as possible .
Keep bystanders out of the area .
Steel cable can cut you in half if it breaks under tension .
