coolbikeguy
Thread starter- Joined
- May 14, 2009
- 491
1975 135 johnson
so while waiting for my carb rebuild kits to get here i decided to drain the lower unit ... i did and it was NASTY so i decided to remove it to do a flush with some diesel fuel.... here what i found when i pulled it off ...
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c001.jpg
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c002.jpg
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c003.jpg
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c004.jpg
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c005.jpg ..... broke out bolt passage for some reason ??? its ok up in the mid leg though and will still get tight
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c012.jpg .... lots of dirt
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c009.jpg ... also found one of my vernatherm valves under the wasp nest in a previous pic... guess ill be tearing down the thermo housings to check these out ... ugggghhhh
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c016.jpg .... water pump housing
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c013.jpg .... impeller which is stuck to shaft ... what the trick to removing a stuck impeller ??
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c014.jpg ... another impeller pic
http://s74.photobucket.com/albums/i269/coolbikeguy/?action=view¤t=135c018.jpg .... so i figured while im into it i might aswell take the cover off that the shift rod goes into just to have a look .... well ... of course all 4 bolts snapped off and the cover ( part# 385544 ) is no longer available according to marine engine.com in case i break it. theres a bunch of that white corrosion down in the bolt holes where they snapped off .... should i still be able to pry the cover off then try and get the bolts out ?? or do i have to drill them out now ??
also .... is there a way to back flush the engine to make sure the water jackets arent clogged up ??
if i move the shift rod up or down i should be able to get it in gear right ?? how much force should it take to move the rod up or down ??
anything else i should be looking for ???
thanks guys, scott
thanks guys, scott
