Screens will just plug up, the best way to do a drain and know that it will drain is an actual drain. Iboats drains in the link below, you'll have to scroll through the searches as there's some that are not what you need.
In my cabin of the Chief I have a regular 1" splashwell drain tube in the aft end of the deck. Nothing will plug it up and you can see if it's covered up.
https://www.iboats.com/shop/pumps-an...in-covers.html
Should oil have come out like this? Or could it have been where I had it laying down a few weeks until I built a stand for it? It's a'73 E-rude.
My Sprayit kit arrived last night. Looking forward to life after rattle cans.My Sprayit kit arrived last night. Looking forward to life after rattle cans.
Looks like a couple days of much needed rain, heading out on a scavenger hunt for assorted bolts, screws and hardware needs as well as a couple more hole saws to finish the vents.
Couldn't figure out what was what, then I got it.
I was talking about two different things in a thread.
1. The limber holes (yes, water). I was noting the fact that I'd left a small gap at the bottom of each bulkhead (raised deck forward, full-width bench at SW), for water to drain back to the bilge area.
2. I was making a vent using hole saws (there is a pic of that), and talking about putting screen wire or something on the back side to keep critters out.
The vents you provided the link to would definitely work, but I want it to be a one-of-a-kind, kind of thing (and I'm cheap), and have the materials on hand to make something.
Yeah that holes along the side, it's a good idea, I like that. Not sure it's "one of a kind" tho :lol:
My SS I have them as a pass through for my fishing rods with a holder for the butts.
[IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/rujl8q.bn.files.1drv.com\/y4mwbfTEcYyP-Y-KT-rizJaUAYzqjXbegwE85uH9KbeNQgiE8Yl4DiFDbYbh5Gacvk5K5rMDLThT_Hxw2dHwRR8tREcdwOWC0r9P6NDBjMhhRuZnSJ21aqyNN6MgzobIaRPiqnQ0KNvianVN8BzxbE4hCMdU32lxbJlvY5t7NSEDMgrN3w9Fv3yj94lCreDkDwm-cCXgY_iqK5KzbvqUhxAtg?width=1024&height=768&cropmode=none"**[/IMG2]
I got one of the Attwood semi-custom covers in 300 for my Chief, I really like it so far. You have to make a support from PVC pipe or similar though to keep the water from pooling or it will ruin the cover.
The 600 cover I got for my SS sits folded up since it's in the garage all the time when not in use. You could get away with a 150 cover if you had a car port but out in the sun and wind it will go pretty quick.
