140 Mercruiser Wellcraft wiring/ fuse help
drivin79
I don't have any readings on my tac or engine temp gauages. The only fuses that I can find on the boat are the ones on the insturment panel. I can't find a fuse board or anything. Does anyone know where it might be if it has one at all? Secondly, where do the wires for the temp and tac go into the engine. The tac is read by the alternator if i'm correct, but where do the temp wire go?
Skippy J
Re: 140 Mercruiser Wellcraft wiring/ fuse help
Temp wire goes to temp sending unit right under the thermostat housing. Brass looking plug with one wire to it. Can't miss it ( resistance only no fuse ). Remove this sending unit wire and with key turned on touch wire to sending unit body. The temp gauge should immediatly peg to highest temp. If not bad wire, if it pegs wire good-bad sending unit.
I learned this from this forum, I did not stay at a Holiday Inn Express last night.
Skippy J
Ayuh,... The Tach get's it's signal from the Coil,+ the Temp Gauge has a Sensor, usually mounted in the T-Stat Housing...
Ayuh,.... Welcome Aboad, Drivin',.... I posted on your Other Thread.....
You only have to post 1 question,....
If you don't see it when you return to the forum page,...
Hit your Refresh Button,+ it'll magicly appear at the Top...;)
Don S
I merged the two posts into one.
Ayuh,... Thanks Don...
Been pretty Busy, Huh,..?? Haven't been seeing ya like winter time,...:D :rolleyes:
JustJason
Winters over????? :)
I mean around here it feels like it went from winter to fall again.
Winters over?????
Hope so,... I took my carhart coveralls outa the truck today,+ tossed 'em in the wash....
JustJason
Did you change the oil in your jeans while you were at it? :p
